Recieving error on virtual tour
gumbert_ryan
by gumbert_ryan » Sun Feb 12, 2017 12:14 am
When trying to view a tour I have posted on my Wordpress site i'm receiving the following error code; "ERROR. Adobe Flashplayer or HTML5 Browser with WebGL or CSS3D support required", I have other tours posted on the same page that are working perfectly fine though. Does anyone have any idea why I may be encountering this problem?
Re: Recieving error on virtual tour
by Destiny » Sun Feb 12, 2017 2:20 am
Hi.. I think with Wordpress you have to add support for Flash.. Not sure.. https://wordpress.org/plugins/wp-flash/
by Annis » Mon Feb 13, 2017 10:40 am
What version of PTP was used?
What is your computer configuration and your browser+version?
Can you share the link to the tour?
How did you integrate the tour to your website?
gumbert_ryan
by gumbert_ryan » Wed Feb 15, 2017 11:20 pm
The PTP version was the one before the most recent 2.5 update.
The configuration I'm encountering the problem with is a Windows computer using Internet Explorer.
The tour was integrated to my website through the PanoPress plugin.
by Annis » Thu Feb 16, 2017 9:35 am
Is it win7 and IE?
If so, that can be expected due to the combination of old browser + old OS and not being detected correctly, as the browser should be able to support HTML5.
