Multiple Google Analytics Codes in a Tour   [SOLVED] - View the solution
justinmih
Liked in: 3 posts
by justinmih » Thu Feb 02, 2017 1:31 am
Hi
I posted this on the "Using Panotour" forum in December but haven't had any answer and i was wondering if anyone on here could answer this for me?
I was wondering if its possible to add 2 google analytics codes to one tour?
I am aware that this is possible with Google Analytics but wondered if its possible to achieve this on a tour?
Can anyone tell me which files i would need to amend to get this to work?
Kind Regards
Justin
Diner21959
Likes: 10 posts
Liked in: 3 posts
Re: Multiple Google Analytics Codes in a Tour
by Diner21959 » Fri Feb 03, 2017 4:17 am
Best way to find out is to add both codes to the tour and then test it.
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Multiple Google Analytics Codes in a Tour  [SOLVED]
by 360-compunics-com-ni » Fri Feb 03, 2017 5:38 pm
The PTP analytics plugin was not designed to handle 2 tracking codes within the same tour, and you cannot simply add it twice to your project. Having 2 codes would require major modifications to the plugin, feel free to contact me for an individual quote.
Btw, if you want to track tour visitors activity and not only want to know the panos they visit, have a look at the GATE plugin: http://www.kolor.com/forum/viewtopic.php?f=40&t=34442
Kind regards,
Michael
