Control function to Move to specific Panorama
pDiem
by pDiem » Wed Feb 01, 2017 2:25 pm
Hey guys,#
is there any controlpad style, that allows users to jump from any panorama to a specific one?
Like I want to have something lie the widely known "Home" Button, just for more than one panorama.
For Example:
I want to enable my users to jump to Frontdesk or Shop XY or similar, wherever they are in my tour.
I know that I could build something like that using a few plugins and CSS/HTML. But is there already a preset?
Thanks!
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Control function to Move to specific Panorama
by 360-compunics-com-ni » Sat Feb 04, 2017 4:11 am
I'm not aware of any controlpad modifications that would offer this option.
There is a way to always go to one specific target pano using the "startscene"-feature of the controlpad: when you re-define the "startscene"-variable after the startscene has been shown, the home button will always bring your visitors to that new "startscene". That can be done using the "Call actions on tour events"-plugin, setting it to call the "custom KRPano code" (another additional plugin needed for this) after the tour has started, the call would be as follows:
set(startscene,<panoid-of-your-target-pano>);
pDiem likes this post.
by Annis » Mon Feb 06, 2017 12:12 pm
Why not just use a panorama menu? You'll be creating a menu with buttons to each of your panoramas...
pDiem
by pDiem » Mon Feb 06, 2017 12:18 pm
The panorama group with buttons might work. But I have to put my destination panoramas in one group and only display that.
Once the interactivity is too much the menu gets flooded and is not really usable.
