too many files - ptv webviewer!?   [SOLVED] - View the solution
moffoys
by moffoys » Tue Jan 31, 2017 12:36 pm
my webhoster has a file limit on 256.000 files. i host many tours and we need more than 256.000 files.
the problem is, one tour has over 6.000 files, this is many. Is it possible to compress the tour to a zip and read this zip as a normal tour? an another solution are a ptv webviewer.
Anyway, the handling from one file are better than 6.000 files. I need a solution to make from 6000 files (as sample) to 1 file on my webspace :-) i don't know is this possible.
moffoys
Re: too many files - ptv webviewer!?
by moffoys » Tue Jan 31, 2017 4:17 pm
self resolved with PHP! zip your Tour, upload it and make an index.php with follow code:
<?php
$handle = fopen('zip://vr.zip#index.html', 'r');
$result = '';
while (!feof($handle)) {
$result .= fread($handle, 8192);
fclose($handle);
echo $result;
it works!!! the php open the tour from the zip file. awesome!
Likes: 14 posts
by bdd » Tue Jan 31, 2017 4:26 pm
With such workaround, you will face other limits.
Try for example to access your tour on different devices at same time.
Your server may face some memory limits as the tour will be unzipped in memory on server side.
moffoys
by moffoys » Tue Jan 31, 2017 4:36 pm
yeah, it doesnt work. it only open the index.html, blank site! is there a solution to make it possible?
Re: too many files - ptv webviewer!?  [SOLVED]
by Annis » Mon Feb 06, 2017 12:05 pm
There is no solution, you can't englobe the entire virtual tour (which is a web page) in a single file with all it's resources.
That was only possible in Flash.
