Black Preview in Scene Properties Issue
Re: Black Preview in Scene Properties Issue
by Annis » Wed Jan 10, 2018 5:13 pm
You can use your Panotour Pro 2 licence with any 2.X version.
The issue seems to be caused by an incompatibility with the graphics driver (since it's from 2016) and the latest version of the software so your best bet here would be to use an older version which was compatible.
Dennisw
Liked in: 3 posts
by Dennisw » Wed Jan 10, 2018 10:10 pm
Thank you Annis. I will see how 2.5.4 works then.
FWIW, there is one other little observation I can offer. I have no idea if it helps you but why not? Without an operational preview pane I am struggling to guess FOV and YAW adjustments numerically. I noticed that when I delete the FOV number in preparing to type in a different value (e.g. starting with 90.00 then deleting the 9 to get 0.00 and then the 0 to get .00 before making it 70.00 let's say) the black preview screen displays a central grey vertical bar, positioned not unlike the icon in that pane for setting the default view (but grey, not coloured). It goes away and and the pane becomes solid black again when I put numbers back in the box to the left of the decimal point.
Cheers... Dennis
Dennisw
Liked in: 3 posts
by Dennisw » Thu Jan 11, 2018 4:41 pm
Good News Annis
I stumbled over the FAQ "Multiple GPUs" which led me to discover that PanoTour had not registered with the nVidia Control Panel, and even when I did add it it had chosen to use the integrated Intel graphics and not the nVidia card. Now I have a functioning preview pane! Thanks
benji33 likes this post.
elena8
by elena8 » Tue Apr 03, 2018 1:52 pm
I just downloaded the latest version 2.5.10 and the issue is still there!!!! Now I have window 10. It is very hard to work like that!!!
by benji33 » Thu Apr 19, 2018 3:10 pm
What is your graphical card(s) and drivers versions please Elena8 ?
TimK
by TimK » Tue May 01, 2018 5:10 am
Hi Admins:
I don't believe the problem has been solved yet.
Here is my computer spec what has the problem:
Windows 10 64-bit
EVGA GeForce 1060 6GB (Version 397.31 & 4/25/2018)
Panotour Version2.5.11 64bits
but I have another computer which doesn't have the problem:
Windows 10 64-bit
EVGA GeForce 1070 (Version not sure, will update later)
by benji33 » Wed May 02, 2018 9:31 am
Hi TimK is there some specificities on your 1060 config?
The NVidia card is used to control the software?
elena8
by elena8 » Mon May 14, 2018 7:46 pm
I have windows 10 64 bit
nvidia v. 388.71 GeForce GT 540 M
Pano Tour Version 2.5.11 64 bit
Still have the problem
paulcreedy
by paulcreedy » Mon Aug 27, 2018 9:20 pm
I have the black preview screen in one of my tours and I think I know how to reproduce it, but not fix it.
The tour was working fine until I clicked that blue globe and box above the preview wondering what it does. It's at that moment the preview stopped working and wont come back.
paulcreedy
by paulcreedy » Mon Aug 27, 2018 9:42 pm
I've been able to reproduce this on my PC and reproduced a fix, at least on my pc during the time I was testing it.
Clicking the BOX above the preview and then the Globe often caused my preview to go black.
Taking a screenshot of the settings whilst it was working, I can see that the FOV went from 90 to .50 Setting both FOV values (preview and default view) back to 90 caused my preview to reappear.
Whether this is repeatable on other sessions remains to be seen.
Previous
