Calling for a website with a Website Box   [SOLVED] - View the solution
Maukoop.nl
by Maukoop.nl » Fri Jan 06, 2017 1:23 pm
I am doing something wrong it seems. May be you can tell me where to look.
I am creating point hot spots in order to get a website box. This should open a webpage. However, via the 3rd Party plugin Simple button for specific panorama's it does not work. Neither does it work with the original plugin: "simple button."
I set the action to open website box on tour.
When I click the hotspot, the window opens. The website however does not load, the windows stays empty.
I am on macOS Sierra (latest) with PTP2.5.5. Is there anybody who can advise?
Re: Calling for a website with a Website Box
by Annis » Fri Jan 06, 2017 1:25 pm
What is the website?
Some websites can't be displayed in website boxes (which are basically iFrames) because of the http/https concurrency, which means if you display a https website on a http site, or vice versa, it'll be blocked.
There are also some websites that are configured to block being shown in iFrames completely.
Maukoop.nl
by Maukoop.nl » Fri Jan 06, 2017 1:29 pm
I tried may be 5 to 10 different websites. Any examples which are known to be working?
by Annis » Fri Jan 06, 2017 1:48 pm
Kolor.com and the forum will work in the website box.
How are you viewing the tour, is it online?
Maukoop.nl
by Maukoop.nl » Fri Jan 06, 2017 1:54 pm
I'm loading it while Kolor is open, via localhost. It's not online.
Should I add 'http://' or 'https://' in the website url?
Maukoop.nl
Re: Calling for a website with a Website Box  [SOLVED]
by Maukoop.nl » Fri Jan 06, 2017 2:01 pm
I am sorry, but I created a new website box in the workspace, and started building this thing up again. It seems opening my websites again. I am sure it did not do this with my other "Website Box" plugins, I'll try to look for differences in settings.
by Annis » Fri Jan 06, 2017 2:05 pm
Which browser? What exactly is the URL you're using?
Using kolor.com or www.kolor.com, Panotour will add the http:// automatically and loads the website just fine.
Maukoop.nl
by Maukoop.nl » Fri Jan 06, 2017 2:07 pm
I got it working with Safari now. It is because I created a Website Box plugin in the project, and fixed a new hotspot to this.
I am now trying to reproduce these steps to get it all working. Seems good for now.
