A BUG has been clear   [SOLVED] - View the solution
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Mon Oct 31, 2016 4:10 pm
My English is not good, See the screenshot.
Re: A BUG has been clear
by Annis » Thu Nov 03, 2016 4:29 pm
It's a url field. When you enter text, PTP is expecting a url and will complete it if needed.
Say you wanted to open the website kolor.com.
If you input www.kolor.com PTP will complete it as necessary to make it a full url.
If you input http://www.kolor.com then PTP will leave it as is.
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Tue Mar 07, 2017 4:00 pm
Hi Annis, Thanks for your reply.
I'm trying to say is : The generated code, the two " data " and " name " value is the same.
Dashan
eMail: 446426990@qq.com dspano@live.cn
Re: A BUG has been clear  [SOLVED]
by Annis » Tue Mar 07, 2017 4:10 pm
Is this issue still current?
I'd have thought it would be related to the issue 0005888 from the changelog that was fixed in 2.5.7:
- 0005888: [Tour] Message IDs of actions parameters are the same if the actions are inside an ElementList (issue in Sidebar plugin)
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Thu Mar 09, 2017 4:10 am
Great! =D
- [Tour] Message IDs of actions parameters are the same if the actions are inside an ElementList (issue in Sidebar plugin)
Dashan
