a3impressies wrote:how can i restore to chrome older versions?
And what if my client has the same version / troubles? Strange behavior just on an apple platform ( macbook - imac) with this chrome version.
Hey Pierre,
Welcome to the Google Chrome Help Forum!
Can you clarify a few details:
Are you on a Domain or a Managed system?
Does this happen on other browsers as well?
Does this happen in Incognito Mode (Ctrl+Shift+N)? If this doesn't occur here, then one of the extension might be causing the problem. I'd suggest you try disabling the extensions one by one (under Chrome://extensions) to see which one is bringing on the issue.
Here are some steps that you can try:
Your profile account might have been corrupted. Try creating a new browser user profile and check on the off chance that it makes a difference.
Run a scan with malwarebytes. This will help in removing the malicious software from the computer which tends to conflict with Chrome.
In case you're using an antivirus or firewall software, ensure Chrome is trusted or permitted by these programs. You can also try temporarily disabling your antivirus or firewall to check whether this determines the issue.
Let me know your findings!
Best,
Beena
