Video with alpha channel support, causes software crash
Peterp
by Peterp » Fri Oct 14, 2016 12:59 pm
It seems like .mov clips with alpha channel are not supported in Panotour, right now these clips are causing the program to crash. Is there any way to import transparant clips or will there be in the near future?
thanks.
yordiv
Re: Video with alpha channel support, causes software crash
by yordiv » Fri Feb 10, 2017 5:47 pm
Bump
I need this too and have the same problem!
Extra info: when building .Flv files in Panotour 2.5.6, it also crash.
by Annis » Mon Feb 13, 2017 10:37 am
Transparent .mov files are working formats they are not final formats supported in software other than editing software (like Premiere Pro), or readable in browsers.
However .flv should be supported as long as you have enabled the Flash player and add flash=prefer to the URL, did you submit a crash report with your e-mail?
