Hotspot problem   [SOLVED] - View the solution
Sean King
Liked in: 4 posts
Hotspot problem
by Sean King » Sun Sep 11, 2016 8:36 am
I have an animated hotspot that functions on the desktop but just show a black square on mobiles.
I have tried the png at both 24bit and 32 bit but it still only shows the black square.
Any help would be appreciated
Regards
Liked in: 442 posts
Re: Hotspot problem
by Annis » Mon Sep 12, 2016 8:36 am
Can you share a link to the tour?
If you transfer the image on it's own to your mobile, can you view it?
Sean King
Liked in: 4 posts
Re: Hotspot problem
by Sean King » Mon Sep 12, 2016 9:17 am
Hi Annis,
I can view the image on my mobile phone when I transfer it. but not in the tour.
I have pm you the information.
Thanks for the help
Liked in: 442 posts
Re: Hotspot problem  [SOLVED]
by Annis » Mon Sep 12, 2016 10:20 am
I think the issue is the size of the file.
I've resized the spots file to 60 and 40 (tried two versions) and they work.
Sean King
Liked in: 4 posts
Re: Hotspot problem
by Sean King » Tue Sep 13, 2016 6:44 am
Perfect, that did the trick.
Thank you
Annis likes this post.
