Video doesn't play in VR mode   [SOLVED] - View the solution
VR2GO
by VR2GO » Thu Aug 25, 2016 7:24 pm
Hello guys,
I used Panotour Pro v.2.5.3. to do a video virtual tour. Everything works fine in 2D mode but when I switch to VR mode and press play, it crashes directly and I get this error message: Image
Here is the link if you wish to give it a try: http://vr2go.ca/Virtual%20Tours/Jackalo ... index.html
Videos are standard mp4 H.264 exported from Adobe Premiere CC.
I tried it on a Samsung S6 and Xperia Z1, the problem is the same.
Any input on the problem would be much appreciated.
Thanks,
VR2GO
Re: Video doesn't play in VR mode  [SOLVED]
by VR2GO » Tue Aug 30, 2016 4:29 pm
Solved with 2.5.4!
