Can not open Panotour Pro 2.5.3   [SOLVED] - View the solution
Klexy
by Klexy » Wed Aug 24, 2016 10:09 am
Dear Members
I had a Problem with Panotour Pro 2.5.3 since two weeks i could´t start it. My GPU driver is the newest vor my Nvidia GT420M. I deinstalled Panotour and install it again but nothing help. I add Panotour to the list in the Nvidia settings but nothing help. Please help me i need it for work Iam a real estatet agent.
Thank you Klexy ;)
Re: Can not open Panotour Pro 2.5.3
by Annis » Wed Aug 24, 2016 3:32 pm
If you right click on the icon and select "Launch as administrator" does it launch?
Do you have any bloatware that isn't compatible with Win10 installed such as Dell recovery and backup software?
What is your anti-virus?
Klexy
by Klexy » Wed Aug 24, 2016 3:51 pm
Thanks for the answer. I try right click yesterday but it also do not work. Bloatware is not on the PC. My antivirus is Panda Endpoint Protection. The Problem is I search and search but i didn´t change someting on my PC that could be the problem. No new Software, no new hardware. I send a email to Kolor with the error report but no answer. I also search in the Forum. My second software from Kolor work thats AutopanoGiga but in the momemt I need Panotour ;)
by gkaefer » Wed Aug 24, 2016 11:10 pm
The hint from Annis about antivirus software is meant as:
1. if you use any kind of av software
2. and you face problems now where never had problems in past
3. than just for a test inactivate you av software for a test
4. to try to start ptp successfully again.
I had this same issue in past years once, some others too.
also try to uninstall ptp and reinstall it again.... may also help too - had it too once in past....
Klexy
by Klexy » Thu Aug 25, 2016 10:04 am
Thank you gkaefer for you answer. But it don´t work.
Klexy
by Klexy » Thu Aug 25, 2016 10:55 am
I call us IT specialist and he found the Problem. We don´t know from wich Programm it comes but it was a Lavasoft.dll we named the dll´s to old and now it work. I don´t know if one other Software need these dll´s but we think not.I post the screenshot of the error.
Klexy
by Klexy » Thu Aug 25, 2016 11:30 am
The only thing´s that not work are search updates and the Start site to click the presets and the last tours. But its better so than it did not open and i could do nothing. I could load the presets manual under styles.
The solution is not optimal if you change the name from the lavasoft.dll the remotedesktop don´t work.
Also if someone had the answer how the probelm get realy fixed please let me know.
Re: Can not open Panotour Pro 2.5.3  [SOLVED]
by Annis » Thu Aug 25, 2016 3:17 pm
Lavasoft is an antivirus that typically has issues with our software, other users have reported that the only solution was to deactivate or uninstall lavasoft.
I'm sorry however I didn't understand your last post. Are you running the software on a virtual machine?
Klexy
by Klexy » Thu Aug 25, 2016 3:40 pm
Thanks Annis for the Time.
The Problem is I didn´t install Lavasoft. Panotour and Giga are lokal on my notebook. The lavasoft.dll also could be a virus or malware we check it. If it is one of these two it could be a filter that block something from Panotour. After my IT specialist give me a call and we fix it I let you know whats going wrong. If its a mistake from my side I´am sorry
