Pano Speed   [SOLVED] - View the solution
Orange01
Pano Speed
by Orange01 » Thu Jul 21, 2016 3:48 am
Hi there, I have a technical question for someone.... I've created a Panotour that goes from a 360 degree image to a standard photo, the problem is that the speed from standard photo to photo is really fast (it makes it all seem like a video game...) and from 360 to 360 it goes at a gentle speed that works nicely... How do I fix this? Anyone?
Cheers
Glen
Liked in: 443 posts
Re: Pano Speed  [SOLVED]
by Annis » Mon Jul 25, 2016 11:13 am
What are your autorotation settings?
You could set specific autorotation settings for your standard photo, namely a slower speed if you think it's too fast on planar scenes.
Orange01
Re: Pano Speed
by Orange01 » Mon Aug 29, 2016 11:42 pm
Have some how only just seen this reply, will try looking at those Autorotation speeds and see how I go. Many thanks for your help. Cheers.
