Links not working properly   [SOLVED] - View the solution
duotone
by duotone » Fri Jul 15, 2016 1:14 am
Please follow these steps to re-create bug:
This is only an issue when the pano is a video pano.
Can you please issue a fix? Please?
Thanks,
Tony
duotone
Re: Links not working properly
by duotone » Wed Jul 20, 2016 1:20 am
So, no help from KOLOR on this issue?
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Wed Jul 20, 2016 5:44 am
Hi Tony
Looks like a great tour but as you indicated appears to have things that do not work. Does it work when ran from within Panotour? I have found that if you delete all the files from the build directory and build again, basically regenerate everything it sometimes solves problems. If that works delete all files from your server and reupload. The problem could also be with running the tour from dropbox.
Steve
by Annis » Mon Jul 25, 2016 11:05 am
Sorry for the delay.
It's already a registered bug, reported here and here.
No workaround or solution at the moment.
duotone
by duotone » Tue Aug 30, 2016 6:25 am
Annis, is this going to be fixed?
Re: Links not working properly  [SOLVED]
by Annis » Thu Sep 01, 2016 2:45 pm
Have you downloaded PTP 2.5.4 released on Tuesday?
From the changelog:
- 0005816: [Tour] 360 video : scene not displayed when getting back on it
duotone
by duotone » Sat Sep 03, 2016 3:15 am
Sweet. I'll try.
