Hotspots/Graphics Appear Offline but not Online   [SOLVED] - View the solution
snafubar
by snafubar » Sat Jun 11, 2016 1:17 am
Hello everyone, I'm having trouble getting my hotspots to appear after manually uploading via FTP to my site.
MacBook Pro, OSX 10.11.5
PTP 2.3.2
Multiple browsers tested.
My tour is extremely simple. 1 image, 2 logos and 2 hotspots. After I "build" the tour and view if offline, everything works normally. But after uploading the files, multiple times to confirm I hadn't screwed anything up, I cannot get the hotspots or graphics to appear. I can even see them in the xxxxxxx_data folder of my tour. What could be causing this?
here's a link to the tour. There are supposed to be two hotspots on the dash of the aircraft, as well as logos on the upper right and lower right of the screen.
http://www.parallaxpoint.com/test-page/
Thanks very much,
Kit
Re: Hotspots/Graphics Appear Offline but not Online
by Annis » Mon Jun 13, 2016 8:32 am
Files are coming up with a 404 error when viewing the tour, check the files are uploaded and they have the correct permissions to be viewed publicly from your server.
Also, why are you not using the latest version of PTP?
snafubar
by snafubar » Mon Jun 13, 2016 5:28 pm
Hi Annis, thanks for the response. I will double-check the files and the permissions... is there anything specific I should look for with the permissions ? I am simply uploading the files manually through FileZilla, which I have not had a problem with in the past.
To answer your second question, I am not using PTP 2.5 because I was having even greater problems trying to get the online versions of my tours to appear correctly. Namely, after I uploaded manually using FileZilla and linked the tour using the iFrame method used on my entire site, the tour would fail to load at all. So I began testing older versions of PTP, and found that this issue did not occur with PTP 2.3. It works well except for the hotspot issue above.
Thank you again,
Kit
snafubar
Re: Hotspots/Graphics Appear Offline but not Online  [SOLVED]
by snafubar » Sat Jun 18, 2016 1:42 am
I found a solution by switching FTP clients.
Apparently Filezilla (multiple versions) for OSX was causing some sort of issue with my uploads. I switched to CyberDuck and everything seems to be working normally again.
Thanks!
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Sat Jun 18, 2016 8:37 am
I have also found lots of problems with the newer versions of Filezilla, I downloaded an older version, 3.5.2 and it works fine.
Steve
