resolution issue with spherical projection since v2.5.3   [SOLVED] - View the solution
aircamera
by aircamera » Thu May 19, 2016 3:03 pm
I'm using a 22376x8389px image as introduction image for a tour.
This image is not 180x360°, but I'm using spherical projection anyway to produce a semi spherical image (153°x50°).
It was working correctly before v2.5.3, but now, I have strange resolution issue on this picture only.
Look at the attached files to see what it looks like now when I'm zooming in.
before
before
after
after
here is a temporary link to see the tour :
http://www.aircamera.fr/visite_virtuelle/pleney_ete/360.html spherical projection with bug in resolution and spot size.
http://www.aircamera.fr/visite_virtuelle/VTT/360.html plannar projection works
I could use plannar projection, exept that I need FOV toogle plugin which is no more supported. And spots size do not get bigger when we zoom in...
If someone can help me, I would be so much grateful !
Thank you very much !
Re: resolution issue with spherical projection since v2.5.3  [SOLVED]
by Annis » Thu May 19, 2016 3:34 pm
Partial panoramas with multi-resolution are not supported in the HTML5 player, they only get mono-resolution which is limited to the cube-faces.
See here: http://www.kolor.com/wiki-en/action/vie ... player_.3F
