Image won't load
360Trooper
Image won't load
by 360Trooper » Thu May 12, 2016 1:26 am
]ok so I have made a few tours and posted on google drive. For some reason my last two tours are not working properly. I have done everything the same way as my old ones but neither of the new ones are not working. I even tried transferring from my website and still won't work but when i preview in panotour it works. What is the problem. Here is a screen shot showing some of the errors.
Re: Image won't load
by Destiny » Thu May 12, 2016 3:50 am
Hi... Perhaps you have filled up your space allocation on the Google Drive.. This screen shot clearly shows your images are missing.. I suggest you try to upload again and also check your space..
Destiny....
360Trooper
by 360Trooper » Thu May 12, 2016 6:12 am
I have not exceeded my space and also have uploaded to my website as well. This screen shot was taken from my website not Google Drive, as I thought the problem was originally with Google Drive. I have uploaded the file a couple times and even tried rebuilding it then uploading it. My next try is to build it from scratch. When I look at my files on the website it is showing everything in the folders.
by Annis » Thu May 12, 2016 9:24 am
Can you share the link to your tour?
Do the files have the correct permissions to be viewed? (if they don't then in this case they can come up as missing)
360Trooper
by 360Trooper » Thu May 12, 2016 4:37 pm
by Annis » Fri May 13, 2016 9:22 am
I don't see any tour on that page
360Trooper
by 360Trooper » Sat May 14, 2016 11:37 pm
http://360trooper.com/Tour/OutAndAbout.html
sorry i sent an old link. It seems to be working today on two different browsers so I am not sure what that was acting up.
by Annis » Tue May 17, 2016 9:44 am
Well, Google Drive soon won't be allowing web page hosting so it's possible they're testing modifications on their side for that. The tour works fine now.
