Bootstrapmenu and VR-mode not working
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Fri Apr 01, 2016 3:40 am
I found when using the bootstrap template and the vr mode that:
1. The menu is still visible in vr.
2. The exit vr and setup button (in vr mode are gone).
Can someone reproduce this error?
I used an iphone 6 for testing.
Regards,
Xander Berkenhagen
Re: Bootstrapmenu and VR-mode not working
by Annis » Fri Apr 01, 2016 8:06 am
Which template specifically are you using?
Which version? (you can find the date at the end of the bootstrap template's template name)
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Fri Apr 01, 2016 11:45 am
The template I use is:
Bootstrap_Top_Navbar_-_Responsive
I think it was the latest 10-2015
by Annis » Fri Apr 01, 2016 3:01 pm
Could you make sure it is the latest? Try downloading it and reinstalling then rebuilding the tour.
I've just tested it with this template and VR Mode works fine.
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Sat Apr 02, 2016 4:57 pm
Hi Annis,
Yes it was the latest template.
I download it also again and rebuild the tour... but no change.
In this picture you see what I get with the current template:
1. I can still see the bootstrap menu.
2. The return to desktop and settings icon is not shown when touching the screen
The next picture shows what I get with the fullscreen template, you can see the icons for settings and return to desktop.
So I think the bootstrap template is not up to date for working with VR...
What is your idea?
Regards,
Xander
