skin elements shown bigger online   [SOLVED] - View the solution
ittay
by ittay » Mon Mar 28, 2016 2:49 pm
Hi
At local preview (build tour) all skin elements looks correct. when files tour online I get all skin element shown bigger from what they should, something like 20% bigger.
Is there any solution ?
PT 2.5.2 64 bit
Re: skin elements shown bigger online
by mediavets » Mon Mar 28, 2016 7:00 pm
ittay wrote:Hi
PT 2.5.2 64 bit
Which browser and OS are you using to view the online tour?
ittay
by ittay » Mon Mar 28, 2016 7:45 pm
Window 7. FF, Chrome
Re: skin elements shown bigger online  [SOLVED]
by Annis » Tue Mar 29, 2016 8:05 am
Could you share the URL to the tour, and/or a screenshot of the tour offline and a screenshot of the online tour?
Are you certain you haven't increased the size of the page or domain you've uploaded the tour on? (Try pressing on Ctrl + Numpad 0)
ittay
by ittay » Tue Mar 29, 2016 2:37 pm
It was my fault. its OK now.
I did increased the size of the page ...
Thank you !
Annis likes this post.
