Adding hotspots in the test version of Panotour
nigelwalshe
Likes: 3 posts
by nigelwalshe » Sun Mar 27, 2016 3:30 pm
Hi there
As a newcomer to the virtual tour world, I am experimenting with the trial version of Panotour 2.5 before commiting to purchase. I seem to be experiencing a graphics problem - I can load 5 spherical panoramas, and can build and save the tour, but the images don't appear in the workspace, only the file names in a flickering font. Also, if I try to use the hotspot editor to insert hotspots, the program immediately crashes.
My apologies if I'm missing something obvious here, but any help would be much appreciated.
All the best
Nigel
Re: Adding hotspots in the test version of Panotour
by mediavets » Mon Mar 28, 2016 7:05 pm
Check that you have the latest available graphics drivers.
nigelwalshe likes this post.
nigelwalshe
Likes: 3 posts
by nigelwalshe » Mon Mar 28, 2016 7:45 pm
Thanks for the reply! The drivers all are up to date. Since the original post, I've found that the program works fine on an old Vista laptop. I'm beginning to wonder if there's an incompatibility with some of my other programs on my main computer - I run Phtotoshop, Photomatix, PanoV2R, PTGui amongst others, as well as a tablet.
by Annis » Tue Mar 29, 2016 8:09 am
If the software crashes, were you prompted to send in a crash report?
If you have, could you send, it with your e-mail in the e-mail field so that we can find it and try to find the reason of the crash?
by benji33 » Tue Mar 29, 2016 8:20 am
Try also to reinstall Panotour Pro to see if issue can be solved with a reinstall.
nigelwalshe
Likes: 3 posts
by nigelwalshe » Tue Mar 29, 2016 10:19 am
Annis wrote:If the software crashes, were you prompted to send in a crash report?
Many thanks for the reply! All I get is a Windows message saying Panotour has stopped working, followed by a box saying that Windows will let me know if it comes up with a solution. I've also reinstalled the program twice now, with the same result.
nigelwalshe
Likes: 3 posts
by nigelwalshe » Tue Mar 29, 2016 1:20 pm
benji33 wrote:Try also to reinstall Panotour Pro to see if issue can be solved with a reinstall.
Thanks Benjamin! I've reinstalled it twice on my machine, but no improvement. I have also installed it on our other desktop (also Windows 7) and it doesn't run at all - the interface on opening is completely garbled. Yet for some crazy reason it works on a clapped out old laptop running Vista!!
