Is this possible with panotour?   [SOLVED] - View the solution
jakedonahue
by jakedonahue » Tue Mar 15, 2016 10:16 pm
I'm still learning the ins and outs of panotour, and I already know I'll need to upgrade to Pro to achieve much of what I want. But once I do, will I be able to create an interface like this: https://tour.lcp360.com/nocache/centurylink/
Does anyone have any examples of something similar? I obviously don't need it to look exactly like that link (I believe they used KrPano for this after looking at the source code -- though I could be mistaken), but something like that would be awesome.
Thanks!
Re: Is this possible with panotour?  [SOLVED]
by Annis » Thu Mar 17, 2016 4:46 pm
Hello, and welcome to the forum,
You are correct, it was coded with KrPano, so you wouldn't be able to get that exact tour.
Let's break down the elements (from what I can see) and then I'll make a second one from this one with what can be done in Panotour:
- Custom cursor
- Projections in the contextual menu (right click menu)
- Links in the contextual menu (right click menu)
- Arrow hotspots for navigation
- Header image (the white background at the top)
- Top corner logo
- Panorama menu
- Groups of panoramas (Main level / Delta Sky360 / Etc..)
- Floorplan
- Multi-floorplan with selector
- Floorplan button
- Contact us button
- Panorama title
- Thumbnails menu with tabs
- Control Bar
- Loading bar (at the bottom of the screen)
Can be done in Panotour Pro (the links are to the documentation on the concerned plugins):
- Projections in the contextual menu - http://www.kolor.com/wiki-en/action/vie ... ntext_Menu
- Links in the contextual menu - See above
- Header image (the white background at the top) - http://www.kolor.com/wiki-en/action/vie ... one#Header
- Top corner logo - It's actuall a simple button, with the action of navigating back to the first panorama, though a logo plugin also exists ;) - http://www.kolor.com/wiki-en/action/vie ... ple_Button
- Panorama menu - Not responsive though, it does not group into one button and long list like in your example - http://www.kolor.com/wiki-en/action/vie ... orama_Menu
- Floorplan
- Multi-floorplan with selector - The selector is a drop-down menu, not a slider of thumbnails of the floorplan - http://www.kolor.com/wiki-en/action/vie ... Floor_Plan
- Floorplan button - it's a simple button
- Contact us button - it's a simple button
- Panorama title - http://www.kolor.com/wiki-en/action/vie ... zone#Title
- Thumbnails menu with tabs - No tabs, but you can have a thumbnails menu - http://www.kolor.com/wiki-en/action/vie ... Thumbnails
- Control Bar - http://www.kolor.com/wiki-en/action/vie ... ontrol_bar
- Loading bar (at the bottom of the screen) - http://www.kolor.com/wiki-en/action/vie ... d_Loopings
The rest was either hand coded or not supported (custom cursors are Flash-only, for example).
You can try recreating the tour in the demo version of Panotour Pro.
If there are any features I may have missed and you have any questions on, just ask!
jakedonahue
by jakedonahue » Sat Mar 26, 2016 6:35 pm
Wow, thank you for the detailed reply! Very helpful.
Annis likes this post.
