No responsiveness of content in website box on mobile
Redmar
by Redmar » Mon Feb 15, 2016 6:34 pm
We use website boxes inside our tours. The website box and responsive content scale perfectly on a desktop browser. On mobile devices the content of the website box doesn't scale.
I've set up a test tour:
http://fotofotofoto.nl/responsive_website_boxes/
Direct link to the hotspot content loaded inside the website box which scales correctly on mobile devices:
http://fotofotofoto.nl/html/responsive_code/
I've attached some screenshots from the tour and the advanced settings of the website box.
Hope someone can help us find a solution!
Full width (max 600px) website box, correct scaling:
Desktop full width website box
Scaled website box on a desktop, correct scaling:
Desktop scaled
Wrong / no scaling of the website box content (mobile / Iphone, etc):
Iphone
Advanced settings of the website box:
Advanced settings
nicgac likes this post.
Re: No responsiveness of content in website box on mobile
by Destiny » Tue Feb 23, 2016 10:37 pm
Hi.. Your setting for mobile devices is set to 1100 X 800.. Try making this smaller.. Your Desktop is set to 600 X 800.. You could try making them the same.. See if that makes difference..
Redmar
by Redmar » Wed Feb 24, 2016 6:07 pm
I've uploaded a new version; both settings are now 600x800. The problem is still the same; it seems that every setting above 300px causes problems on mobile devices. If I set it on max width of 300px the view on a mobile device is good but it looks bad on an ipad (very small pop-up) ;)
http://fotofotofoto.nl/responsive_website_boxes_v2/
Hoping for a solution; would it be possible to create a new plugin for this so it can be solved?
Marmolada Production
by Marmolada Production » Thu Feb 25, 2016 1:12 am
I've got the same problem... I create a specific html that open on website box but on mobile responsive's not working. I've also noticed that if I change the "max scrollable for mobile/tablet devices" does not affect on mobile (I tried on Android only, it seems like does not reconize mobile devices)
by Destiny » Thu Feb 25, 2016 8:29 am
Hi.. Could you please send me a link to the Website Box content.. I think the issue is the code in that html...
by Destiny » Thu Feb 25, 2016 10:46 am
Hi.. I carried out some test... I made a test pano with an image.. There seems to be nothing wrong with PTP, however Firefox has some real issues with the hotspot being totally unresponsive.. I am sure its the way you have added your image into the html page.. Test this on your mobile..
http://www.destinyvirtualtours.com/imag ... obile.html
If out works then try editing your html to something like this below... I think I have it right.. But you might have to tinker with it... or Kolor might have other ideas..
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<meta content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" name="viewport">
<style type="text/css">
body {
margin-left: 0px;
margin-top: 0px;
img.test {
width: 100%;
height: auto;
</style>
</head>
<body width = "device-width">
<img class="test" src="image2.jpg">
</body>
Redmar
by Redmar » Thu Feb 25, 2016 11:56 am
Thanks for helping out. Unfortunately I'm pretty sure that the problem lies with Kolor and not with the HTML code. I've tested your example on several devices and on all of them the image doesn't scale. The difference is hard to spot since you used an image with the size of 600*800 and modern phones can display this without resizing.
Just to be sure I've created a new version with your HTML code and my image (1600x1067px):
http://fotofotofoto.nl/responsive_website_boxes_v3/
As you can see the image isn't responsive here as well.
I think a website box should be able to serve content responsively and I'm hoping for a Kolor response on this subject.
Screenshot of Destiny's example on a simulated Iphone 4:
Screenshot of Destiny's example on a simulated Iphone 6 plus:
by Marmolada Production » Thu Feb 25, 2016 12:06 pm
If you'd like to have a look to mine too: http://www.santa-croce.it/virtualtour.html (the box are on the "i" hotspot)
This is one html, I've created it with dreamviewer using a responsive template: http://www.santa-croce.it/santa_croce_v ... olada.html
Redmar
by Redmar » Thu Feb 25, 2016 12:54 pm
Same problem:
Iphone 4:
Desktop scales good.
by Marmolada Production » Thu Feb 25, 2016 1:59 pm
What mobile emulation do you use?
I searched on Internet but found nothing really appreciable..
Redmar
by Redmar » Thu Feb 25, 2016 2:02 pm
Just use the developer tools in Chrome and click on the phone icon (bottom left)
https://developer.chrome.com/devtools
Redmar
by Redmar » Fri Feb 26, 2016 11:34 am
I'll be out of the country / office for two weeks so I won't be able to perform additional tests. I hope someone from Kolor will come with an official response since we would like to give our clients a solution.
by benji33 » Fri Feb 26, 2016 4:52 pm
Try to reduce the max scrollable width value for mobile/tablet (by default it's 1100 pixels which is too large for a mobile screen)
There is only one setting for all mobile/tablet device. So try it into portrait mode rather than landscape.
Redmar
by Redmar » Sat Feb 27, 2016 3:21 am
This is not an option; the only resolution that works on all phones is a maximum width of about 250 px; this looks very bad on a tablet. Furthermore; the box itselve is responsive on a mobile device; somehow the content doesn't scale. It really looks like there is a problem with the code output of Panotour website boxes.
Link to the new tour; mobile maximum width 250px:
http://fotofotofoto.nl/responsive_website_boxes_v4/
Maximum width 250px Iphone 4, looks OK
Maximum width 250px Ipad, looks bad:(
From now on I won't be able to upload new tours for 2 weeks since I'm out of the country. Hope there wille be a permanent solution and if not; we're looking for someone who can develop a custom plugin to solve this problem.
by benji33 » Tue Mar 01, 2016 2:25 pm
This issue is linked to the iframe usage which is not able to grab the iframe size into mobile device. So it's not possible to get the iframe content display size and the size must be set manually to be able to scroll document.
I know it's a huge limitation.
We'll try to do better later.
by Destiny » Tue Mar 01, 2016 9:27 pm
:rolleyes:
Jeremiahscott
by Jeremiahscott » Thu Mar 03, 2016 4:19 am
please keep us posted on this fix! this is a biggy! I'm also having a lot of issues with the tours on mobile. I have lost several clients who pull up the tours on mobile but due to the loss of responsive design on their phones the content quality gets lost in the translation.
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Sat Mar 12, 2016 12:45 am
Anything new on this?
micheleborghesi
by micheleborghesi » Thu Mar 31, 2016 8:51 am
I have the same problem. I opened a new thread by mistake: http://www.kolor.com/forum/viewtopic.php?f=92&t=31099&p=180932#p180932
Did anybody found a workaroud?
Michele
nicgac
Likes: 3 posts
by nicgac » Thu May 05, 2016 1:32 pm
Resolved (on my side)
suti1984
by suti1984 » Mon May 30, 2016 12:04 pm
I can generally create such InfoIcon with popup ? I can not find the function
Redmar
by Redmar » Tue May 31, 2016 9:44 am
nicgac wrote:Resolved (on my side)
Could you let us know how you solved this issue? We're still hoping for Kolor to pick this up!
justinmih
Liked in: 3 posts
by justinmih » Thu Jun 02, 2016 11:55 pm
Hi
I have previously raised a similar responsive issue (see topic viewtopic.php?f=92&t=31154) and was told that plugins are not responsive. On things like logo there is an option to change the scale from pixels to percentage and this means that the logo remains the same percentage size of the given screen so gives the impression that it's responsive. Perhaps if the web box had the option of percentage (and all plugins) then this may be a quick fix for something that is clearly causing issues for a number of us.
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
by FunkyPunky » Sat Jun 04, 2016 9:45 am
Same issue here. Kolor please solve it!
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Mon Jun 06, 2016 1:46 pm
Any idea when this will be solved? working on a big project that needs responsive website boxes.
