Panotour 2.5 Pro - how to restrict viewing angle?
Michael Ezra
by Michael Ezra » Sun Feb 14, 2016 3:30 pm
I have a spherical panorama jpg file which is about 160 degrees horizontal FOV and 69 vertical
How can I use this jpg in PTP to let it spin only 160 degrees and not show black areas?
I tried with image as-is, also tried with the same image when I expanded canvas to simulate 360x180 pano and then cropped it (with a trick of setting input horizontal FOV to 359), still I get black areas on left and right when pano spins. How do I make it stop at the edge of the image?
Michael Ezra
Re: Panotour 2.5 Pro - how to restrict viewing angle?
by Michael Ezra » Sun Feb 14, 2016 3:49 pm
Quick update... I tried viewing the tour in the internet explorer 11.09 and it works correctly. Does not work in Firefox 44.0.2
by benji33 » Mon Feb 22, 2016 10:37 am
Tested you image into PTP 2.5 with 160° x 68.64° without issue into Firefox.
by Annis » Mon Feb 22, 2016 10:55 am
After you've cropped the image in the hotspot editor (to hide the black areas) make sure you empty your cache.
