[PTPro 2.5 Winx64] popup image not adapting to screen size   [SOLVED] - View the solution
Michael Ezra
by Michael Ezra » Mon Feb 01, 2016 8:52 pm
When image is displayed on-click of the hotspot, image is not sized to the resolution of the screen and it is impossible to zoom out to see the entire image or to scroll. this is easy to see on Galaxy Note 5 - although it has resolution 2500x1440 when popup image is 1200 px long, it extends beyond the screen area.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: [PTPro 2.5 Winx64] popup image not adapting to screen si  [SOLVED]
by Cliquetsy » Mon Feb 01, 2016 9:19 pm
Did you check the advanced option "Limit size to viewer size" or something in the display an image action properties?
Michael Ezra
by Michael Ezra » Mon Feb 01, 2016 9:58 pm
I found it, its in style, properties of Display an image plugin. Thanks for pointing it out!
