[PTPro 2.5 Winx64] Cannot generate tour in high resolution   [SOLVED] - View the solution
Michael Ezra
by Michael Ezra » Mon Feb 01, 2016 4:05 pm
Please explain how this can be achieved, I tried all options I could find in the interface. Panos are 22000x5000 but tour output is limited to about 1200px height.
Re: [PTPro 2.5 Winx64] Cannot generate tour in high resoluti  [SOLVED]
by Annis » Mon Feb 01, 2016 4:12 pm
Your panoramas are partial panoramas.
Partial panoramas with multi-resolution are not supported in the HTML5 player, they only get mono-resolution which is limited to the cube-faces.
See here: http://www.kolor.com/wiki-en/action/vie ... player_.3F
Michael Ezra
by Michael Ezra » Mon Feb 01, 2016 4:17 pm
I am not clear on what to do.. Could you please explain what settings should I use to get high resolution panorama.
Where can I set the output size?
by Annis » Mon Feb 01, 2016 4:23 pm
Set the projection to planar, and you won't need to edit the panorama to get multi-resolution.
If you want to stick to a spherical projection, you need to render the panorama as a full 360x180° panorama so that you can access multi-resolution.
1) In Autopano, you can force the panorama to increase the crop zone so that it will cover the entire sphere.
force full equi.png (20.67 KiB) Viewed 2255 times
2) You can then virtually crop the black areas out of the panorama in the hotspot editor of Panotour.
hotspot editor crop.png (11.81 KiB) Viewed 2255 times
Michael Ezra
by Michael Ezra » Mon Feb 01, 2016 8:55 pm
Thanks, I will try this. However, I already have some panos which were rendered and manually edited to correct misalignments, etc. Would this work if I simply add black space on top and bottom to obtain image aspect ration 2x1?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Mon Feb 01, 2016 9:16 pm
Yes it would.
