[PTPro 2.5 Winx64] Cannot move point hotspots
Michael Ezra
by Michael Ezra » Mon Feb 01, 2016 4:02 pm
Simple drag does not work. Ctrl-drag moves hotspot, but when mouse is released, hotspot is jumping back to original location.
Re: [PTPro 2.5 Winx64] Cannot move point hotspots
by Annis » Mon Feb 01, 2016 4:09 pm
Have you using the point hotspot tool or are you using the select tool which only selects (for editing the hotspot properties)?
You need to use the same hotspot type as the one you are trying to move.
Michael Ezra
by Michael Ezra » Mon Feb 01, 2016 4:13 pm
Correct, hotspots can be moved with hotspot tool only, not the select tool... just found out:)
You seem to have half-implemented Ctrl-drag for moving, that is confusing:) It would be more intuitive if hotspots don't jump after dragging.
benji33 likes this post.
