Error loading jpg   [SOLVED] - View the solution
zil-imu
Error loading jpg
by zil-imu » Tue Jan 26, 2016 5:31 am
I have uploaded my tour in a password protected moodle page and got this error:
Error: loading of ../html5/filename.jpg failed!
The problem for all browser except firefox. In firefox everything is working fine.
Please help
Re: Error loading jpg  [SOLVED]
by benji33 » Tue Jan 26, 2016 9:52 am
Into the main xml generated into YOURTOURdata there is a <security> tag.
Update the cors="" value to cors="use-credentials"
cyb
by cyb » Tue Jan 26, 2016 4:54 pm
How is that supposed to help? I'm getting the same problem.
by benji33 » Wed Jan 27, 2016 9:39 am
If there is a password protection the browser need to know the credentials and the tour too.
http://krpano.com/docu/xml/#security
zil-imu
by zil-imu » Thu Jan 28, 2016 2:18 am
Thanks for your respond. I am unable to find the <security> tag and code that you've mentioned. The main XML file is somehow encrypted. I am using the trial version for testing. Please help
by Annis » Thu Jan 28, 2016 9:18 am
XML can't be edited with the trial version, it's one of the demo limitations.
by benji33 » Thu Jan 28, 2016 9:36 am
Not possible to manage secured tour into the Panotour (not Pro) version due to this edit.
I add a feature request to be able to build a tour with security tag also on the not Pro version.
zil-imu
by zil-imu » Fri Jan 29, 2016 2:39 am
Is it possible to decrypt the XML file. I really need to test this before buying the pro version. Please help
by benji33 » Fri Jan 29, 2016 9:40 am
No, it's not possible to decrypt encoded files.
