Hotspot size according to zoom level in planar panoramas
Virtuel Rundtur
by Virtuel Rundtur » Fri Dec 04, 2015 1:02 pm
Hi Kolor
I can't make my hotspot change size according to zoom level in a planar panorama. Is there any solution underway for this?
Will it be fixed in the final version?
Best regards
Henrik
signmaster
Likes: 52 posts
Liked in: 36 posts
Re: Hotspot size according to zoom level in planar panoramas
by signmaster » Sun Jun 05, 2016 8:11 am
Hi Kolor
I have the same problem. When "Planar" output projection selected and "Change size according to zoom level" is selected the hotspots do not change size according to zoom level. Works OK when spherical projection selected. Is there a timeline for having this fixed as it is a feature that I really need for a project I am working on.
Steve
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Mon Jun 06, 2016 1:44 pm
Any feedback from Kolor as to when this might be fixed?
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Thu Jun 09, 2016 1:00 am
Any response from Kolor?
