Sound not working automaticaly on mobile   [SOLVED] - View the solution
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Thu Nov 12, 2015 1:43 pm
I added a soundfile to a pano.
On the desktop the soundfile starts as expected. But on my iphone it does not start. Only when I disable and then enable the sound in the tour menu...
This is in 2.3 on mac.
Regards,
Xander
Re: Sound not working automaticaly on mobile
by Annis » Thu Nov 12, 2015 2:03 pm
As with many elements of a tour that autostart, on a mobile they require a user action to start, if only just pressing on the pano.
http://www.kolor.com/wiki-en/action/vie ... n_a_mobile
Does the sound not start at all when interacting with the tour, outside of switching the sound on and off?
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Thu Nov 12, 2015 3:08 pm
Nope it does not start at all. Only when using the mute button...
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Thu Nov 12, 2015 7:46 pm
Do you have a link to your tour you can share?
Xander Berkenhagen
Liked in: 8 posts
Re: Sound not working automaticaly on mobile  [SOLVED]
by Xander Berkenhagen » Fri Nov 13, 2015 11:08 pm
I just got it to work...
I removed the sound, and put it back in.
Cliquetsy likes this post.
