XML Parser Error
Xander Berkenhagen
Liked in: 8 posts
XML Parser Error
by Xander Berkenhagen » Mon Oct 12, 2015 11:42 pm
Hi Guys,
I was working on a project.. And after building it gave me and error when running the tour..
I did build it yesterday and it worked fine.
Screenshot
It happened in PTP pro 2.3. on Mac.
Do you have any idea what caused this? Can you solve the error in the file?
Regards,
Xander
KMA.kpt
Project file
(361.7 KiB) Downloaded 35 times
Re: XML Parser Error
by benji33 » Tue Oct 13, 2015 10:09 am
You can send me the kma_skin.xml file please ?
by benji33 » Tue Oct 13, 2015 10:46 am
To solve this, remove spaces into the "Start Notofication Hindernisbaan" plugin name.
What is the version of this plugin ? the latest one ?
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Tue Oct 13, 2015 12:12 pm
Hi Benjamin,
Yes, it is the latest one... I updated all the plugins 1-2 weeks ago.
by benji33 » Tue Oct 13, 2015 12:16 pm
So report this issue on plugin name with space (with this forum post link) to Alex. Popov to be solved into next release of the plugin.
Alexpopov
Likes: 21 posts
Liked in: 28 posts
by Alexpopov » Tue Oct 13, 2015 1:01 pm
I would not call this a bug :) because it is noticed in the documentation
...Avoid using space in names.
Example: "My notif img" - not correct, but "My_notif_img" or Mynotifimg or My-notif-img are correct...
I'll check if it is possible to improve for future releases.
Best!
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Tue Oct 13, 2015 1:55 pm
Hi Alexander,
Thanks for the explanation!
Then it's probably a bug in my head :-) (Men reading manuals :-)
Regards
