Change tooltip font of hotspot   [SOLVED] - View the solution
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Mon Oct 05, 2015 7:28 pm
Hi guys,
Is it possible to change the font of the tooltip for a hotspot?
Regards,
Xander
Re: Change tooltip font of hotspot  [SOLVED]
by benji33 » Tue Oct 06, 2015 8:34 am
If you want to use basic web fonts, you can use this :
If you want to use Google fonts for instance have a look here (only for HTML5 export) : http://360cityguides.com/worldwide/chan ... o-project/
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Tue Oct 06, 2015 4:19 pm
Ah thanks... It was there :-)
