Panotour 2.3.1 right click issue on macbook
Tim92
by Tim92 » Tue Dec 30, 2014 12:00 am
I can't open the context menu in the hotspot editor with the touchpad of my macbook.
every time i click right the menu opens -> closes and then the picture zoom in.
if the maximum zoom is reached it works.
The bug happens only with the touchpad not with an external mouse
same on the tour overview if i would delete a panorama
Re: Panotour 2.3.1 right click issue on macbook
by mediavets » Tue Dec 30, 2014 12:20 am
Tim92 wrote:I can't open the context menu in the hotspot editor with the touchpad of my macbook.
Welcome to the forum...
It seems you have a 'solution'?
Tim92
by Tim92 » Tue Dec 30, 2014 12:22 am
thats only a workaround but in the tour overview it doesn't work with this way
by mediavets » Tue Dec 30, 2014 12:43 am
Tim92 wrote:thats only a workaround but in the tour overview it doesn't work with this way
Which version of OSX are you running?
Tim92
by Tim92 » Tue Dec 30, 2014 12:44 am
10.10.1 on a 2013 15" Macbook
by mediavets » Tue Dec 30, 2014 12:55 am
Tim92 wrote:10.10.1 on a 2013 15" Macbook
My understanding is that PT/PTP is not yet fully compatible with 10.10.1.
Tim92
by Tim92 » Tue Dec 30, 2014 12:58 am
ok
i hope this will be fixed soon, i want to buy a license and use it for my work
Tim92
by Tim92 » Wed Dec 31, 2014 8:49 pm
i testet 2.3.0 an in this version are no problems
by benji33 » Fri Jan 02, 2015 9:32 am
Thanks I report the problem.
DArt
by DArt » Tue Jan 27, 2015 2:22 pm
It is a bug in one of our external libraries. Same problem on Maverick too. The workaround is to use Ctrl+touch to open the contextual menu instead of 2 fingers ways (that causes the bug).
We works on that problem but it is not depending of our code.
