I've downgraded from 2.31 to 2.30 :-(
leifs
by leifs » Thu Dec 25, 2014 11:42 pm
An upgrade from x.30 to x.31 is supposed to fix bugs, not to introduce new ones. I was happily upgrading from PTP 2.30 to 2.31 and expected it to be a nobrainer. Not so !
It killed my favourite start for my panos, a zoomout.
I achieved it editing the XML lik this:
<autorotate horizon="13.718485" tofov="30.581294" waittime="5" speed="5"/>
altered to
<autorotate horizon="13.718485" tofov="90.0" waittime="5" speed="5"/>
In 2.31 it doesn't work, for some reason or another. So I have downgraded to 2.30 :-(
here is two builds, 2.30 and 2.31 for a pano:
ptp 2.30, like I want it / expect it to work
http://www.rundskuer.no/panotour/orstak ... ltour.html
ptp 2.31, it does not zoom out !
leifs
Re: I've downgraded from 2.31 to 2.30 :-(
by Destiny » Fri Dec 26, 2014 5:57 am
Hi... They both work my end.. Both zoom in and out via the menu and by the mouse..
Perhaps clear your cache in your Browser and if your build created a cache file, removed it or at least do not upload it..
Appart from that, who knows.. Very strange..
leifs
by leifs » Fri Dec 26, 2014 9:47 am
does both start autorotate with auto zoomout ?
Leif
by Destiny » Fri Dec 26, 2014 10:16 am
arrr... Well the fist one zooms out but the auto rotate does not work too well, it is very gitty and stops and then a bit more then stops again etc..
The second one does not zoom out but the rotate is a little better but still not good.. Perhaps the jpg quality needs to be lower..
I see what you mean about the zoom out.. I guess thats one for Kolor.. I do not think they will be around until Tuesday.. I think Monday is a holiday in France.. but there again, they might take a few days off.. They sure deserve it...
leifs
by leifs » Fri Dec 26, 2014 10:28 am
Thanks for the try !
I guess it must be a change in the krpano-version from 2.30 to 2.31, or some issue like that. The XML is identical for the autorotate statement.
I have two parallell installs of PTP 2.30 and 2.31.
The two online panos are generated straight forward with each of them and uploaded to two different folders online.
They should have behaved in exactly the same way.
Leif
update:
in the virtualtour_skin.xml it says
<krpano version="1.18">
so it must be something else than a krpano version issue
PTP is set to make jpeg quality = 9, like I've been using for years
can't see why this pano should be jittery now
Likes: 14 posts
by bdd » Mon Dec 29, 2014 10:38 am
I reproduced your issue.
It seems to be a krpano flash player issue.
I do not get the error with the HTML5 player, even with your tour :
http://www.rundskuer.no/panotour/orstak ... ml5=prefer
I changed the player used by Panotour Pro 2.3.1 (krpano 1.18.2) by the one used by the 2.3.0 version (krpano 1.18.1)
I will ask Klaus (krpano developper) if it is a known issue.
leifs
by leifs » Wed Jan 21, 2015 11:52 pm
the "html5=prefer" trick doesn't work on cylindrical panos. like this one:
http://www.rundskuer.no/panotour/blaani ... ml5=prefer
the pano is not interesting in itself, it's just my first non-spherical pano for a long time. and I'm disapointed to see that there is a bug in 2.31 ignoring the tofov="80.0" statement in the XML
<autorotate horizon="15.560939" tofov="80.0" waittime="5" speed="5"/>
I expect it to be rectified asap.
leifs
by benji33 » Thu Jan 22, 2015 9:55 am
We are waiting too for a krpano patch into the next 1.18.3 release. Issue is in the 1.18.2 version.
leifs
by leifs » Fri Jan 23, 2015 8:37 pm
until then my workaround are:
- make the tour in 2.31
- build it in 2.30
it works fine for me but I'm looking forward to a fix.
leifs
