Bug Galore…
jarane
Re: Bug Galore…
by jarane » Mon Dec 15, 2014 6:00 am
Thanks,
I'll start looking right now. hopefully that'll take care of some of the issues.
E.
Re: Bug Galore…
by benji33 » Mon Dec 15, 2014 10:17 am
Some files are not loaded on your hosting, have a look on 404 errors
Re: Bug Galore…
by Destiny » Mon Dec 15, 2014 10:25 am
All code files.. Bit like Joomla where it doesn't like JS or CSS files added.. I think its the same with the Godaddy Server.. There are restrictions.. I think its still possible though, but you need to contact the tech team... Hardly worth the bother, might as well find an alternative host..
Re: Bug Galore…
by mediavets » Mon Dec 15, 2014 1:10 pm
Could be a files permissions issue?
jarane
Re: Bug Galore…
by jarane » Thu Dec 18, 2014 11:03 pm
Weird,
krpano Klaus just told me he knows of no issues with Godaddy (??)
Anyone recommends a good... (sorry... GREAT!!!) host for panos?
E.
Re: Bug Galore…
by mediavets » Thu Dec 18, 2014 11:09 pm
jarane wrote:Weird,
E.
Did you check file permissions on the served?
How did you upload their tour files to their server?
jarane
Re: Bug Galore…
by jarane » Thu Dec 18, 2014 11:13 pm
How do I check permissions on the server?
I upload everything via Fetch.
E.
Re: Bug Galore…
by Destiny » Thu Dec 18, 2014 11:15 pm
If you do a search on this Forum, you will find many others who have had issues with Godaddy, so perhaps you will find your answer there.. I remember reading something about permissions..
jarane
Re: Bug Galore…
by jarane » Thu Dec 18, 2014 11:17 pm
Thanks,
will try that.
E.
Re: Bug Galore…
by Destiny » Thu Dec 18, 2014 11:18 pm
In your server folder, right mouse on the folder and check to see the read/write permissions. I think you need to set it to 777. Thats the control you may have. However, it might be the administrator that has to give more.. Really not sure.. Try that first then contact Godaddy..
Re: Bug Galore…
by Destiny » Thu Dec 18, 2014 11:21 pm
This is a screen shot of my permissions options.. I can apply to any folder and sub-folders... But my other server provider, I cannot do this. I have to contact the administrator to edit it..
Re: Bug Galore…
by mediavets » Fri Dec 19, 2014 12:10 am
jarane wrote:How do I check permissions on the server?
E.
Most FTP programs will allow you to view and change file and directory permissions on a server.
Previous
