lookto tween time value not accepting variables   [SOLVED] - View the solution
FlatBallFlyer
by FlatBallFlyer » Thu Oct 23, 2014 2:22 am
Hi, this could be a syntax or coding problem, but given the variable
<krpano foo="4"/>
the following command works as documented
lookto(0.1,0.2,0.12,tween("easeOutQuint",4));
but the following command appears to use a tween time of 0
lookto(0.1,0.2,0.12,tween("easeOutQuint",get(foo)));
Any help appreciated.
Re: lookto tween time value not accepting variables
by benji33 » Thu Oct 23, 2014 8:26 am
Yes I've test it with the same problem. I'll ask krpano developer for this problem. As soon as I've a solution I'll post it here. thanks.
Alexpopov
Likes: 21 posts
Liked in: 28 posts
Re: lookto tween time value not accepting variables  [SOLVED]
by Alexpopov » Fri Oct 24, 2014 7:42 am
I've adviced the solution here: viewtopic.php?f=91&t=23859
Must work ;)
