Cube faces exportation not working well   [SOLVED] - View the solution
Morgan
by Morgan » Wed Oct 22, 2014 7:20 pm
Hello Kolor Team,
I don't yet why but when I select a panorama and try to export a cube faces version of it PTP doesn't do anything.
I have plenty of panoramas and it seems that it doesn't work for large panorama :-(
If there is any limitation please let me know.
For your information it export perfectly the cube faces of this large panorama with Pano2VR....
Thank you.
My panorama dimensions: 25526x12763
My configuration: Windows 8, 64bits, PTP 2.2.0 64bits, 32Go RAM.
Re: Cube faces exportation not working well  [SOLVED]
by benji33 » Thu Oct 23, 2014 8:15 am
Do you load panorama in full resolution (in hotspot editor) before trying to export them ?
I've your tried the PTP 2.3 beta 1 ?
This bug has been resolved : "Unable to export cube faces of panorama not loaded in full resolutions"
Morgan
by Morgan » Thu Oct 23, 2014 8:53 am
Dear Benjamin,
It doesn't work even with full size preview activated, but it works with the new version 2.3 beta.
Thank you for your help.
Morgan
by benji33 » Thu Oct 23, 2014 9:36 am
Thanks for the report Morgan.
Morgan
by Morgan » Tue Oct 28, 2014 6:08 am
Dear Benjamin,
It works with PTP 2.3. Thanks for your help.
Morgan
