Panorama is not replaced by a new!
shovay
Likes: 3 posts
Liked in: 3 posts
by shovay » Tue Sep 23, 2014 8:48 pm
Trying to replace the panorama of the new (corrected) I see that there was a change but in fact, even after re-generation, nothing happens, I see the same old version of the panorama (to change), the only thing that helps is just to remove the old panorama of the project!
Re: Panorama is not replaced by a new!
by benji33 » Wed Sep 24, 2014 8:07 am
Into build screen you can have a look on the generate tiles option to force generation.
I'll have a look on this feature to see if a problem exists in some cases.
marzipano
Liked in: 14 posts
by marzipano » Wed Sep 24, 2014 8:37 am
shovay wrote:Trying to replace the panorama of the new (corrected) I see that there was a change but in fact, even after re-generation, nothing happens, I see the same old version of the panorama (to change), the only thing that helps is just to remove the old panorama of the project!
If you are viewing the results via a web hosting site, I have experienced the same issue.
Large web hosting sites replicate data across different physical sites / servers to improve response and resilience and this can take a few hours during which time you may continue to see the "old" version
Martin
by benji33 » Wed Sep 24, 2014 9:15 am
Yes but in this case we can't bypass the proxy or gateway servers cache.
by klausesser » Wed Sep 24, 2014 11:09 am
Can you please describe how you do that *in detail*?
Did you change *anything* in the naming of the corrected files?
Are you talking about uploading the panorama to the web or working on the desktop?
by Destiny » Wed Sep 24, 2014 11:13 am
You might want to try to delete the Cache file in your Tour and rebuild again...
shovay
Likes: 3 posts
Liked in: 3 posts
by shovay » Mon Oct 06, 2014 6:59 am
Destiny wrote:You might want to try to delete the Cache file in your Tour and rebuild again...
Now when I checked the different options I can say that the problem is in the cache of Chrome, but delete the cache every time it is stupid so the only solution is to generate PTV file and browse it to see all the changes
by Destiny » Mon Oct 06, 2014 7:26 am
NOT the cache of your browser, you need to remove the cache of PTP, which may or may not have been generated during the build.. And this is only a suggestion to try...
shais
Liked in: 3 posts
by shais » Tue Feb 24, 2015 1:18 pm
I just had the same problem. I replaced a panorama with a fixed version. different file name. I finally deleted the cache file and all build files and this fixed the problem
