Panotour Pro Web Map not opening
Susmit
by Susmit » Fri Aug 08, 2014 6:48 pm
Hi There
I am testing the Panotour Pro 2.0 which my friend has just bought from you. I need to get three licenses thats why i wanted to be sure before i moved from PTP 1.8.
The first problem that i see is that the web map just refuses to open. We have tried to open it from the main workspace by clicking the globe which appears on the left bottom screen, but it just brings up a white blank screen. Only once it had brought the map after trying may be a hundred times. Also putting the LAT/LONG in the Geolocalisation area and clicking the globe beside it also does nothing but again bring up a blank screen.
I tried checking your tutorial videos but there its taken for granted that the map is opening. Is there a specific way of opening the map like doing some settings before clicking the globe on the work space.
Can you please solve this problem please.
Thanks and best regards
Susmit Dey
Dubai, UAE
Re: Panotour Pro Web Map not opening
by mediavets » Fri Aug 08, 2014 7:50 pm
Susmit wrote:Hi There
Susmit Dey
Dubai, UAE
Which version of PTP 2.x are you using and on which operating system?
Have you added the Panotour maps plugin to your Workspace?
Likes: 60 posts
Liked in: 169 posts
by benji33 » Tue Aug 12, 2014 9:55 am
Map icon on the Tour workspace call tiles from the web from Google, Bing or openStreetmap. If you have a poor connection it can display a blank space.
Do you have the problem at this time ?
