Is it to big ?
rruiz
Liked in: 5 posts
Is it to big ?
by rruiz » Thu Aug 07, 2014 11:34 pm
I am at the end of the pre-project, but I need two clics to reload the tour in order to run.
www.perproyectos.com/africam
at my computer, as soon as it opens, is more less quick.
I tried to load small images to the project. The sizes are:
>> As an example, a picture property is: 1024x576 and 381 KB
>> Folder with the tour is 250 MB
>> file for Panotourviewer is 229 MB
Can this be considered a big tour?
I have see other tours with more pictures like mine.
I am concern. If the final project is approved, will contain more pics. Actually this project is maybe 1/3 of the real project.
What can you recommend me?
Thanks anticipated
Roberto
Likes: 60 posts
Liked in: 169 posts
Re: Is it to big ?
by benji33 » Tue Aug 12, 2014 10:01 am
Each 1024x576 panorama represent an amount of 4.5Mo in multi-resolution so if you have many panoramas, the 200 Mo seems good.
For instance I've a tour with 6 panoramas in multi-resolution for 300Mo.
Biggest users tours seen on this forum are 300-400 panoramas for many Go of data.
rruiz
Liked in: 5 posts
Re: Is it to big ?
by rruiz » Tue Aug 12, 2014 7:37 pm
On another computer running the tour on the web the error is:
Connection timeout while making map API call. Try to reload the page.
The error seams to be uploading :
gallerybarforasinglepano
The point is that after trying to upload 2 or 3 times, finally the tour runs smooth without issues !
Re: Is it to big ?
by mediavets » Tue Aug 12, 2014 8:42 pm
rruiz wrote:On another computer running the tour on the web the error is:
That relates to a panotour maps plugin call.
rruiz
Liked in: 5 posts
Re: Is it to big ?
by rruiz » Thu Aug 14, 2014 2:50 am
Finally I re-create all the tour (new name, new folder):
http://www.perproyectos.com/africam/
My lessons learned are:
- all the flat pictures less than 1,000 bytes
- all the panos less than 4,000 bytes
- remove audio and create the narrations within Soundcloud
Still the issue is that I need to reload within Crome 3 or 4 times the tour until it loads complete.
Guys is it normal? The tour is 94 MB
Regards
NOTE: Or the issue is my internet conection??
Likes: 60 posts
Liked in: 169 posts
Re: Is it to big ?
by benji33 » Thu Aug 14, 2014 10:18 am
Can't view your tour ! Too long delay to serve the page.
Seems that your hosting is not very good for international bandwidth.
rruiz
Liked in: 5 posts
Re: Is it to big ?
by rruiz » Sat Aug 16, 2014 2:10 am
Well I reviewed what I have at my web page:
20 GB on hard drive and 100 GB for monthly transfer (good or no? I don´t know. I only handle panos within this space and not so much movement).
I am not an expert guy so I consulted a friend that knows about computers.
He reviewed my pano script and said that has instructions that come and go <> come and go , in regards of the pics at the small galleries.
Do I need to change the order of the Plugins/smallgalleryforasinglepano within the Workspace to the top? Currently all of them are at the bottom of all the plugins...
Thanks for the help
Roberto
Do you want to take a look? Here is the project:
https://drive.google.com/file/d/0B2icka ... sp=sharing
Re: Is it to big ?
by mediavets » Sat Aug 16, 2014 8:16 am
rruiz wrote:Finally I re-create all the tour (new name, new folder):
Regards
There appears to be a problem with the performance of your web host.
I have tried to view your tour twice from the UK - on separate days - and both times I got this:
