Panotour 2.2 IE8
kingo
Panotour 2.2 IE8
by kingo » Thu Aug 07, 2014 11:59 am
I am experiencing a problem with IE8 and my panotour. On initial load it is ok, the sliding floorplan opens and operation is normal. However upon selecting another pano and closing then opening the sliding floorplan IE stops and the balloon pops up saying that there was an error and now reopening it in compatibility mode. The problem with compatibility mode is when you select the dropdown from floorplan(multiple floorplans) the Z depth is incorrect and the floorplan list opens behind the floorplan graphic.
Has anyone experienced this ? Appreciate any assistance.. I have a project of over 350 panos which is waiting to be launched.. but the customer still uses IE8 xp.... =( =( =(
Re: Panotour 2.2 IE8
by mediavets » Thu Aug 07, 2014 12:37 pm
kingo wrote:.. but the customer still uses IE8 xp.... =( =( =(
I guess it's not easy to persuade him/her that IE8 and XP are no longer supported by Microsoft and get him/her to switch browsers if not also OS?
kingo
by kingo » Thu Aug 07, 2014 1:03 pm
you would think its end of life product should speak for itself. however with a few thousand pc's. not gonna happen soon unfortunately.
by mediavets » Thu Aug 07, 2014 1:08 pm
kingo wrote:you would think its end of life product should speak for itself. however with a few thousand pc's. not gonna happen soon unfortunately.
The problem lies with the IE8 browser I think. Is your client viewing using the Flash viewer or the HTML5 viewer?
Any chance the client might switch browsers - or also install a second browser - although sticking with XP OS?
Do you experience any problems with tours viewed with, say, Firefox on XP?
kingo
by kingo » Thu Aug 07, 2014 1:42 pm
ie 8 is using the flash browser. tried firefox and its ok. this proem only started with the 2.2 or the one before. so something changed recently
kingo
by kingo » Mon Aug 11, 2014 8:32 am
Hello. Any Kolor staff who can Help ?
Likes: 82 posts
Liked in: 184 posts
by benji33 » Mon Aug 11, 2014 9:33 am
Hi kingo,
Is it possible to make a test with this new attached file ?
Replace the JS file into YourTourdata/graphics/KolorFloorPlan/ directory.
Thanks for your feedback.
kingo
by kingo » Mon Aug 11, 2014 9:43 am
Hi Benji,
Thanks for your file.
I uploaded it, however I am not at work to check.. Were you able to identify the problem ? can you recheck it now ?
Likes: 82 posts
Liked in: 184 posts
by benji33 » Mon Aug 11, 2014 2:31 pm
After verification it seems linked to the Area animation. Avoid floorplan animations on open/close with IE8. A patch will be done into next release if confirmed.
kingo
by kingo » Wed Aug 13, 2014 1:36 am
Thanks a lot. Problem solved. No more compatability issue.
