Can´t Open Tour
rruiz
Liked in: 5 posts
Can´t Open Tour
by rruiz » Mon Aug 04, 2014 10:15 pm
I can open my tour within the software, but not after ulpoaded into the web and also can´t be opened using Panotour Viewer ( I am attaching the error).
Also the strange thing is that the File Manager is telling me that I have 11 missing files, but how do I know which ones are they since they are not in the list. I went through all my pics, panos, files and couldn't find 11 files... what could me wrong?
Thanks anticipated
Roberto
Re: Can´t Open Tour
by mediavets » Mon Aug 04, 2014 10:22 pm
rruiz wrote:I can open my tour within the software, but not after ulpoaded into the web and also can´t be opened using Panotour Viewer ( I am attaching the error).
Thanks anticipated
Roberto
Did you trying building the tour to a new destination folder so you get a complete fresh buiild?
Do you have any accented or otherwise special characters in file and folder names?
rruiz
Liked in: 5 posts
Re: Can´t Open Tour
by rruiz » Tue Aug 05, 2014 1:23 am
Created a new folder and same as described before
Regards
rruiz
Liked in: 5 posts
Re: Can´t Open Tour
by rruiz » Tue Aug 05, 2014 9:38 pm
rruiz wrote:Created a new folder and same as described before
Regards
What I finally did was to create a new tour with the same files in another folder. The other tour was deleted to avoid any dummy links...
Regards
Likes: 84 posts
Liked in: 186 posts
Re: Can´t Open Tour
by benji33 » Tue Aug 12, 2014 10:31 am
Does it solve the problem ?
Yes it seems that some files are not reachable into your first post.
rruiz
Liked in: 5 posts
Re: Can´t Open Tour
by rruiz » Tue Aug 12, 2014 7:10 pm
Yes thanks. I re-did the project. Thanks for asking
