share button change size
elena8
by elena8 » Sun Aug 03, 2014 9:30 am
yesterday I downloaded new version of p.t. 2.2.0 and I open the project I was working and I see that the share button is too small and aswell the pdf file that before was correct size now is too small. I use p.t. with windows 7 64 bit. I try to open a previous tour and there is the same issue even if befor was correct size. For the pdf file I change the max and min pixel and is quite good but I can't understand because before I haven't to do that! And even changing the size the close button and the title are really small. Wath's happens?
by Destiny » Sun Aug 03, 2014 9:55 am
Hi...
Well that's strange..!
It was promised, or at least asked for many times, an option to change the size off the Share Button set but.. Like many news features of PTP, we are still waiting.. However, this does not explain your situation.. Did you edit your xml in any way..
I am wondering if this has to do with your screen revolution.. Do you have it set high.. I am really guessing here since for me the Share is like it has been for a long time.. HUGE! and ugly... :(
elena8
Re: share button change size
by elena8 » Sun Aug 03, 2014 10:33 am
tank you very much Destiny for your interest. I didn't touch the xml (I really don't know nothing about that!) and neither change resolution (is low) so maybe I touch something in the keyboard, but anyway is strange!
Elena
by Destiny » Sun Aug 03, 2014 10:56 am
Yes... It is strange...
Look forward to finding out why from Kolor..
elena8
by elena8 » Sun Aug 03, 2014 11:03 am
Me too!!
Elena
elena8
by elena8 » Sat Aug 09, 2014 3:36 pm
Nobody of the kolor team member can help me? I show you aswell the changes in the pdf box. I change the size but the close button is too small, before was not like that, somebody can please help me?
Thank you
by Destiny » Sat Aug 09, 2014 10:48 pm
It must be your system that doing this.. Its a fixed graphic.... You cannot change the size via the GUI...
No one else has ever reported this issue so I am assuming it must be your computer.. Are our you able to test it on a different computer.. Also, are you able to show and tell a url so we can see if those buttons relate to your sizes...
by benji33 » Tue Aug 12, 2014 9:41 am
What kind of computer are you using ?
Is it ?
A 4K screen : 3840 x 2160 pixels
A 2K screen : 2560 x 1440 pixels
A HD screen : 1920 x 1200 pixels
Is it possible to have the URL of the visit for tests ?
elena8
by elena8 » Sat Aug 16, 2014 4:57 pm
I just upload in the server the tour and the size of share button is ok, but the pdf size is too big just because I change the settings, so know I have to delete the tour and upload again with pdf correction. Somebody knows why in my pc I can't see anymore proprerly the size? Which pc settings I have to change?
Thank you
Elena
by Destiny » Sat Aug 16, 2014 10:41 pm
Hi.. Try Right Mouse for Options.. Not sure on a PC. Ether that go to the Control Panel... If you have a wide monitor, try 1200, but if not keep going down in size... The thing is.. That feature is related to the Fonts Size, like so many features of PTP.. That is why if you try to add an image to the HotSpot, its Font Size deponent.. As far as I know... But there again, I might have misunderstood how it works.. ;)
I am just wondering when Kolor will have a Size option for the Share Button Set which was promised..
by benji33 » Mon Aug 18, 2014 10:53 am
Into PDF viewer code into YOURTOUR_skin.xml file look after theses values (default values) and change them :
      <option name="iframe_default_width" value="600" type="int" />
      <option name="iframe_default_height" value="840" type="int" />
      <option name="iframe_devices_width" value="1024" type="int" />
      <option name="iframe_devices_height" value="5000" type="int" />
elena8
Re:size too small
by elena8 » Sat Jun 13, 2015 12:35 pm
I never resolve the issue about share button and I leave it but now after a PTP crash is change aswell the thumbnails, hot spots, control bar size and it is really difficult to work like that. When I open the project from the data foulder (outside ptp) the sizes are correct, somebody can tell me how can I resolve this issue?
Thank you
Elena
by benji33 » Tue Jun 16, 2015 2:14 pm
Hi elena8, have you tried the Ctrl+0 into the browser to reset the zoom of the browser ?
