Crashing all the time
nvlass
by nvlass » Sat Aug 02, 2014 10:53 pm
I upgrade to the version 2.2 and I have some weird problems
When I try to add background music in one panorama it crash the moment I try to save the project while some other times it crashes at the same time when I choose the music
The same music when I try to add it to the group of panoramas it is OK
I am stack and I have to finish the project
Is it out there a Support? It is a serious problem as I cannot do anything else?
We need really fast a not so buggy version
Liked in: 128 posts
Re: Crashing all the time
by mediavets » Sat Aug 02, 2014 11:11 pm
nvlass wrote:I upgrade to the version 2.2 and I have some weird problems
I was unable to reproduce your problem with PTP 2.2 64-bit on Windows 8.1 Pro.
Liked in: 131 posts
by Destiny » Sun Aug 03, 2014 2:29 am
Hi.
What format is your music in..
Try using a web converter to strip any unwanted data...
nvlass
by nvlass » Sun Aug 03, 2014 9:44 am
Hi I am on Mac platform mavericks
The music is mp3
In another panorama I have add already another music with the same characteristics with no problems
The music is sounds from a sony device that is saving the sounds as an mp3 as I said in other panoramas I use the same kin from sound without problems
nvlass
The music is mp3
Liked in: 131 posts
by Destiny » Sun Aug 03, 2014 10:23 am
Same setup as me..
Are you able to send me the sound file.. ...or a url to the sound file....
I will run a test for you.. dps@westnet.com.au
nvlass
by nvlass » Sun Aug 03, 2014 3:50 pm
I will sent the file as soon I am in my office
nvlass
by nvlass » Sun Aug 03, 2014 6:59 pm
Hi I have sent you the sound file but I think is not that because I have another sound file that is working fine in another panorama, I tried that sound again the same
Then I tried to change the sound file of the working pano again the same now I cannot add a sound file to any of single panoramas
only to groups. To the group of panoramas I can add the same backround sound file without any problems
The project has 147 panoramas in 10 groups
Thanks Nikos
Liked in: 131 posts
by Destiny » Mon Aug 04, 2014 7:09 am
Hi.. Well I added your sound file to a Tour, and a Group with no issues.. I edited the Range to 360 so it plays on full rotation..
To be honest, I would edit your sound file and crop it down and allow it to repeat/loop..
Not sure why you are having issues with it...
nvlass
by nvlass » Mon Aug 04, 2014 7:35 am
I dont know what to do
Is there any support?
I have sent the report 100 times what can I do now?
nvlass
by nvlass » Mon Aug 04, 2014 7:37 am
I tried a new project
I tried to add a music background in one panorama THE SAME THING
Shall I delete and reinstall my Panotour Pro?
Liked in: 131 posts
by Destiny » Mon Aug 04, 2014 7:38 am
Is it just this sound file that has issues...
nvlass
by nvlass » Mon Aug 04, 2014 7:41 am
No it is not the sound file I tried another that right now is working,
In the new panorama project without groups the same problem immediately when I add the sound file the program crashes
Liked in: 131 posts
by Destiny » Mon Aug 04, 2014 7:43 am
Can you please dot point your process to add the sound file...
nvlass
by nvlass » Mon Aug 04, 2014 1:33 pm
I dont understand what do you mean
nvlass
by nvlass » Mon Aug 04, 2014 2:49 pm
I think I understand you mean to add a music hotspot
First problem it doesn't stop the other sounds of the panorama
Nikos
Liked in: 131 posts
by Destiny » Tue Aug 05, 2014 12:45 am
Hi...
I have used your sound file adding it using the Hotspot Editor and then providing parameters for the Directional Sound..
I have added sound to a Hotspot and set it to cut out when other sounds are playing...
I have also added your sound file to a hotspot with 3D sound and settings it to different Directional effects and also set it to turn off when other sounds are playing...
Nothing I try results in a crash... So not sure what is going on your end...
nvlass
by nvlass » Tue Aug 05, 2014 7:42 am
Ok It seems that something is going wrong maybe with my setup?
What shall I do?
Shall reinstall again the program?
Liked in: 131 posts
by Destiny » Tue Aug 05, 2014 8:04 am
Really do not know.. Reinstalling I doubt will make any difference.. Try renaming your sound file and then add it again.. Something might have corrupted....
nvlass
by nvlass » Tue Aug 05, 2014 10:21 am
How can i speak with the support?
Does anyone know
Itried many things
I rename the file, same problem
I tried to add a sound hotspot, I can add the hotspot I can choose the file but the moment I choose another panorama it crashes I dont even try to save it
Nikos
Likes: 41 posts
Liked in: 144 posts
by benji33 » Tue Aug 05, 2014 2:32 pm
I've just read your message.
It seems there is a problem with sound management on your MacOS.
If 2.2 version has too many crashes, you can go back with a 2.1.3 install : http://download.kolor.com/ptp/stable/history.
I'll try to make a test under a MacOS Maverick to validate the problem.
nvlass
by nvlass » Tue Aug 05, 2014 10:55 pm
Maybe has to do with audacity programm as is the latest programm that I installed and then some other plugin in order to export the sound to mp3 can someone try and tell me if that is the problem?
I will try to uninstall the programm
nvlass
by nvlass » Wed Aug 06, 2014 2:40 pm
Unfortunately no solution so far
any Ideas? how to solve the sound issue?
nvlass
by nvlass » Wed Aug 06, 2014 2:49 pm
I tried also to uninstall the Panotour pro and to install again nothing again
Can someone help?
nvlass
by nvlass » Wed Aug 06, 2014 5:32 pm
Suddenly I have the following errors
INFO: Panotour Pro V2.2.0 64bits
INFO: krpano 1.17.4 (build 2014-06-04)
INFO: Flashplayer MAC 14.0.0.145 PlugIn
INFO: Registered to: nvlasiadis
ERROR: soundinterface - loading of "http://localhost:31415/Final%20readydata/sounds/animation_weakup.mp3" failed
ERROR: soundinterface - loading of "http://localhost:31415/Final%20readydata/sounds/sea.mp3" failed
Any help?
Users browsing this forum: No registered users and 9 guests
