[SOLVED] Autorotation not working (v2.2.0)   [SOLVED] - View the solution
spyboy
by spyboy » Fri Aug 01, 2014 12:44 pm
Autorotation isn't working in the latest build for me. (v2.2.0 64bit windows)
I have an overall Autorotation set for my project
direction: right
delay: 3s
Speed: 5 degrees/s
I tried modifying these numbers to see if it would fix it, but it didn't.
I then highlighted all of my panos and forced an override of it, but that didn't work as well.
Kirk
Likes: 82 posts
Liked in: 183 posts
Re: Autorotation not working (v2.2.0)  [SOLVED]
by benji33 » Tue Aug 05, 2014 3:51 pm
Do you have add Start Parameters > Autorotation > Start tour with autorotation / autotour ?
or a control bar to add autorotation or autotour button
spyboy
by spyboy » Wed Aug 06, 2014 12:11 pm
Ah, totally missed the Start parameters options. Got it, thanks!
Kirk
