2.2 unresponsive, reorganizes groups, asks for registration
JKatz
by JKatz » Thu Jul 31, 2014 5:59 pm
I upgraded to 2.2 yesterday and am having some huge problems:
1. Instead of crashing the way previous versions have, allowing me the option to submit a crash report, the program just stops responding (the tool bar reads "Not Responding"). I would normally leave it be and hope it recovers after a bit, but leaving it overnight still left it in that state. I have to force quit through Task Manager almost every time. This would not be so bad if it didn't happen every 15 minutes or so.
2. Every time I reopen my projects, the groups are completely rearranged, mostly on top of each other so I can't see the panos. The project I'm working on right now has 147 panos, so they're all organized in groups, and having to rearrange them every time I reopen the project (after yet another crash) is pretty awful.
3. The program seems to forget it's registered every time I reopen it after one of these crashes. I have to enter my registration information every time I start up the program.
I'm really excited that my project no longer takes a full hour to load when I open it, but at least I got to work on it after it finished then.
Re: 2.2 unresponsive, reorganizes groups, asks for registrat
by mediavets » Thu Jul 31, 2014 7:09 pm
JKatz wrote:I upgraded to 2.2 yesterday and am having some huge problems:
Are you using a 32-bit or 64-bit version of PT/PTP and on which OS?
JKatz
by JKatz » Thu Jul 31, 2014 7:20 pm
64 bit PTP on Windows 7. The program is also starting up in a smaller window size instead of maximized like it previously did, if that has any bearing on the situation.
I attached a screenshot of what the groups are doing. For this particular instance, I was able to save and close the program without issue, and restarted my computer. When I reopened the program, it once again prompted me to register and rearranged all my groups. Not visible: all the panos it hid behind the larger groups.
nvlass
by nvlass » Sat Aug 02, 2014 8:58 am
Hi I have the same Problem
I am on mac version 10.9.4 with 2.6 GHz with 16GB memory
It is really annoying what is happening
The file ia after I organize but when I start after the crash is like the previous member
JKatz
by JKatz » Wed Aug 06, 2014 12:29 am
Are there any updates on this? I've seen several other people posting about the groups being messed up, but I don't know if anyone else is having the issue where it asks to register every time it opens.
Liked in: 442 posts
by Annis » Wed Aug 06, 2014 8:39 am
Regarding the registration, open Panotour, do not open any project, register the software, close it and re-launch it. The registration should be kept this time.
As for the thumbnails organisation in the workspace, the reason has been explained here: viewtopic.php?f=92&t=23108&p=146058#p146058
