Save as a preset - does not work
R3lic
by R3lic » Sun Jul 27, 2014 9:53 am
Hi all,
When I try to "Save as a preset" nothing happen... :(
Is there any special settings for use this?
Load preset contains 6 Kolor preset. It works fine if I load them but I can't save a new one.
PTP v2.1.3 64Bits
Thanks.
Re: Save as a preset - does not work
by Destiny » Sun Jul 27, 2014 10:14 am
Hi...
Seems to work fine on a Mac.. Just Save As Preset after adding plugins, colours and hotspots etc and its then available next time....
R3lic
by R3lic » Sun Jul 27, 2014 10:29 am
Destiny, it works me fine on my Mac too but on my PC doesn't :(
Nothing happen...
Can you check the content of your User directory ? (open PPT, click on the menu "Edit/Open user directory")
Does it contain something ?
What are the access rights of the subdirectories ?
by Destiny » Sun Jul 27, 2014 10:46 am
How strange.. Might have to log that one as a Bug...
orthodoxws
by orthodoxws » Wed Jul 30, 2014 1:12 am
Same problem here. Windows 8.1 (64-bit), Panotour Pro V2.1.3 (64-bit)
Likes: 14 posts
by bdd » Wed Jul 30, 2014 8:51 am
R3lic wrote:When I try to "Save as a preset" nothing happen... :(
PTP v2.1.3 64Bits
orthodoxws wrote:Same problem here. Windows 8.1 (64-bit), Panotour Pro V2.1.3 (64-bit)
Can you check the access rights of the user directory ?
Can you create a file there ?
Presets are saved in the "Kolor/PanotourPro 2/presets/templates" subdirectory of your User directory
This subdirectory if it does not exist, should be created when PTP starts.
orthodoxws
by orthodoxws » Wed Jul 30, 2014 1:20 pm
The directory is there and it is empty. I can create a new file outside of PTP. I even tried giving permission to "Everyone" to modify the directory but PTP is still not saving the preset.
