PTP 2.2 RC1 Load and Exit speeds
BrianLR
Likes: 3 posts
by BrianLR » Thu Jul 24, 2014 8:15 pm
The Documentation in the wiki mentions much improved load times:
Loading time of a project has been significantly reduced: Projects saved from v2.1 and higher load fast whereas releases prior to 2.1 load slowly. The cache feature of Panotour v2.1 significantly increases productivity and reduces drastically the loading time of large Panotour project containing HD panoramas or Gigapixels. ..... For example: Just a quick bench done on the project of the "Lac du Bourget" tour : http://www.kolor.com/virtual-tours/2013 ... rget-lake/
This tour contains 23 panoramas including 3 gigapixels.
Loading this project took 22 minutes with the 2.0 version.
Once saved with the 2.1 version, the load takes 12 seconds!. In this case the opening is 100x faster!!
This feature increases comfort and smoothness in the Hotspot Editor, learn more in Hotspot Editor Low and High Resolution
I am not finding it that fast and the Exit time is very long, for a project of 50 panos, 7 plans, with 21 Notification plugins, 30 gallery plugins and 13 general plugins it take 50 seconds to load the project and around 7 minutes to exit even when I have previously exit the project, reloaded and then made no changes and exit again. This is on a Windows 7 64bit PC with 32Gb RAM 240 SSD and Sandy Bridge iCore 7 2600K CPU (4 core HT = 8 virtual cores). This project on another PC with 8Gb RAM Q6700 Quad core CPU and 2TB HDD took forever to even load!!
BrianLR
Likes: 3 posts
Re: PTP 2.2 RC1 Load and Exit speeds
by BrianLR » Fri Jul 25, 2014 3:55 am
So I kept adding plugins and go to 30 and then 40 Notification plugins and the crashes started when doing other edits like hotspots and then the load times got out of control from 7 to 15 minutes until all ground to a halt. The strange thing is that the Task Manager only showed about 5-6Gb of ram being used even though 20Gb was set aside for PTP. So I loaded the whole project on to an Apple MacBook OS 10.9.4 with 16Gb Ram and a 500Gb SSD and all is working fine no problems.
So there looks like there is still a big problem with the Windows 64bit version of PTP 2.2 RC1 with larger projects and lots of plugins.
BrianLR
Likes: 3 posts
by BrianLR » Fri Jul 25, 2014 6:43 pm
After further work and additions to the project with PTP 2.2 RC1 on Apple Mac I am finding repeated build errors, with the combo Thumbnail+Toolbar missing, it takes more and more attempts at builds to get this to appear. Other than that Mac version is stable and loads and exits reasonably fast.
BrianLR
Likes: 3 posts
by BrianLR » Mon Jul 28, 2014 5:18 pm
Now running PTP 2.2.0 'stable version' and I am still having problems with the combo Thumbnail+Toolbar not showing up all the time on all browsers and some floor plans showing no hotspots. I am not sure if this is because I switched from 2.1.3 'stable' to 2.2 Beta to 2.2 'stable' or switched platforms from Win to Mac or is it the because I have a lot of Notification plugins?. Please can someone help me in how to debug this??
Likes: 14 posts
by bdd » Tue Jul 29, 2014 9:02 am
BrianLR wrote:Now running PTP 2.2.0 'stable version' and I am still having problems with the combo Thumbnail+Toolbar not showing up all the time on all browsers and some floor plans showing no hotspots. I am not sure if this is because I switched from 2.1.3 'stable' to 2.2 Beta to 2.2 'stable' or switched platforms from Win to Mac or is it the because I have a lot of Notification plugins?. Please can someone help me in how to debug this??
1 - Can you share an URL of your tour ?
It will be easier to debug it by looking at the tour, the diffrent errors it may display, the code generated, etc...
2 - Do you have same issue without notification plugins ?
3 - Can you share the project file ?
BrianLR
Likes: 3 posts
by BrianLR » Sun Aug 03, 2014 3:14 am
I found the problems in my choice of options in the plugin with help from Plugin developer. Have fixed these and resolved the on screen errors.
Back to the original problem of this post, in that the project runs fine on Apple Mac but will not load on Window 7, this problem seems to occur on another recent post called 2.2 unresponsive.....
BrianLR
Likes: 3 posts
by BrianLR » Wed Dec 03, 2014 2:26 am
I am still unable to load my large project with over 80 Notification Plugins on my Windows 7 - 64 bit PC with quad core and 32GB RAM and GPU, again I think this is a combination of issues but as this loads on the Apple Mac Pro with only 16GB RAM I think it must have something to do with the memory management on Windows 7 when using third party plugins, do you have any ideas of why this could be? I was hoping 2.3 would fix it but it has not.
Brian
by benji33 » Wed Dec 03, 2014 10:37 am
It doesn't load ?
BrianLR
Likes: 3 posts
by BrianLR » Wed Dec 03, 2014 4:13 pm
One version of the tour with 18 Panos and 30 + Notification Plugins loads very slowly and is extremely slow to close and exit on Windows 7 but loads very quickly on Apple Mac. A larger version with nearly 60 Panos and 80 + plugins will NOT load in Windows 7 but loads quickly on Apple Mac.
by benji33 » Wed Dec 03, 2014 4:31 pm
Set a new temp directory into Edit > Preferences and reboot Panotour.
Is it better on Windows 7 after that ?
BrianLR
Likes: 3 posts
by BrianLR » Wed Dec 03, 2014 5:20 pm
That made no difference, I even deleted the cache file, but still not loading the large tour.
BrianLR
Likes: 3 posts
by BrianLR » Fri Dec 05, 2014 1:51 pm
BrianLR wrote:One version of the tour with 18 Panos and 30 + Notification Plugins loads very slowly and is extremely slow to close and exit on Windows 7 but loads very quickly on Apple Mac. A larger version with nearly 60 Panos and 80 + plugins will NOT load in Windows 7 but loads quickly on Apple Mac.
Here is a link to the tour with 18 Panos and 30 + Notification Plugins that loads very slowly and is extremely slow to close and exit on Windows 7 but loads very quickly on Apple Mac http://photoweblab.net/vassar/VassarResidentialTour.html
BrianLR
Likes: 3 posts
Re: PTP 2.3 Load and Exit speeds
by BrianLR » Fri Dec 05, 2014 2:23 pm
I have also contacted the Plugin developer Alexander Popov and he says " As plugin developer I have plugin interface API - documentation how to create plugins, and there is nothing about Win or Mac difference in plugins handling". Please can you help by supplying details of why this is still an issue PTP 2.3 on Windows and not Mac, or is it a bug?
by benji33 » Fri Dec 05, 2014 2:39 pm
Without the whole project it's difficult to make tests on our side. I've never noticed this problem before.
BrianLR
Likes: 3 posts
by BrianLR » Fri Dec 05, 2014 2:59 pm
The smaller project is about 1.2Gb, if you email me details of your FTP site I could upload it to you.
by benji33 » Fri Dec 05, 2014 3:19 pm
Send it zipped to contact@kolor.com (for benjamin) with a service like https://wetransfer.com if possible. Thanks
BrianLR
Likes: 3 posts
by BrianLR » Fri Dec 05, 2014 4:09 pm
I would rather use a free service like dropbox is that OK.
by benji33 » Fri Dec 05, 2014 4:11 pm
Of course. wetransfer is free until 2Gb
BrianLR
Likes: 3 posts
by BrianLR » Fri Dec 05, 2014 4:12 pm
Do you have version 1.1.9 of the Notification Plugin?
by benji33 » Fri Dec 05, 2014 4:15 pm
No I don't have this one.
BrianLR
Likes: 3 posts
by BrianLR » Fri Dec 05, 2014 4:35 pm
Benjamin, I have just sent the TourZip file now which includes my Kolor User folder with the plugin files, it should be with you now.
You can use this to debug both the loading issue in Windows and the auto appearance of the Description
Thanks, Brian.
by benji33 » Mon Dec 08, 2014 4:57 pm
Ok I reproduce the problem I'll have a look on what happens. Thanks for the files.
