PTP Beta 2.2 knocks out PTP 2.1
by Destiny » Fri Jul 04, 2014 10:58 pm
I installed PTP 2.2 beta and now PTP 2.1 will not work..
Also, my own custom HTML page does not appear in 2.2...
I can see both icons in my Apps folder but only the 2.2 opens..
Re: PTP Beta 2.2 knocks out PTP 2.1
by Destiny » Sun Jul 06, 2014 9:45 am
I had to remove PTP 2.2 and re-install 2.1+.. I tried to re-install 2.2 "Change Location" but that only allows me to change the HD.. Not a folder on the iMac Apps...
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Tue Jul 08, 2014 2:56 pm
I'm on PC but both 2.1 and 2.2 function just fine. Might be a "bad apple"?
The sun will come out, tomorrow... Well if not tomorrow then at least in 4 years and if not 4 years then most definitely 8 years max. But hopefully in 1 year or less.
by Destiny » Wed Jul 09, 2014 9:18 am
Ha.. No such thin as a "Bad Apple" just some "Rotten People" using them.. :lol: :p
I tried to install again but, nope.. I could do a bunch of screen shots but no point.. I cannot direct the PTP 2.2 Beta to install into a separate folder in the Apps.. I am sure if I can do that it will not knock 2.1 out.. I guess I could try on a remote HD and then copy it over.. Not sure if I can do that.... Failing that I will just wait for the stable version.. No rush.. PTP 2.1 has not crashed on me yet... Can't vouch for those PC users though.. ;)
360fotoshoot
by 360fotoshoot » Wed Jul 09, 2014 11:25 am
Hello fm Holland Destiny. Thanks for notifying us on this issue. That's not fun to know. I almost installed v2.2b1 on my iMac too, but now I'll wait. Another thing to add - I noticed that it doesn't allow Branding Free License on the beta release. I got v2.2b1 running on a separate machine to test out the new Parallax feature which worked magic with PTViewer1.0
by Destiny » Wed Jul 09, 2014 1:22 pm
Hey.. Well my advice is to go for it... but!... If you cannot change the location to a 'Folder' within the main App 'Folder', then abort..
Destiny.
multimago
by multimago » Mon Jul 14, 2014 4:34 pm
I can run smoothly both versions on a mac ( application folder in mavericks); however the beta 2.2 is very unstable with my projects. every time I try to export a project made with 2.1 the app crash without saving the index file.
So, we must wait the next version...
Likes: 14 posts
by bdd » Tue Jul 15, 2014 12:35 pm
multimago wrote:I can run smoothly both versions on a mac ( application folder in mavericks); however the beta 2.2 is very unstable with my projects. every time I try to export a project made with 2.1 the app crash without saving the index file.
Looking at the crash reports you uploaded, it seems that the crash occured whle generating the plugins description.
Can you send me your project file, the kpt file?
We will check there why one of your plugin generates the crash.
multimago
by multimago » Wed Jul 16, 2014 4:43 pm
bdd wrote:Can you send me your project file, the kpt file?
done, thanks
by Destiny » Tue Jul 22, 2014 7:54 am
PTP 2.2 RC1 Also knocks out PTP V2.1.. Its never done this before with any update..
I would strongly suggest that anyone updating with the Mac version is NOT TO if you are using PTP for a paid production work.. It's been proven in the past many times that the Beta and RC versions can cause issues...
APG does not do this, and previous updates of PTP never used to do this.. I am unable to change the location to a different folder, I only have the option to install PTP onto a HD.. It HAS to go on the main Mac HD..
