Full Screen Button not working on iPad
RS360VTS
Liked in: 3 posts
by RS360VTS » Fri May 30, 2014 11:50 am
Hi Guys,
I have created a tour for a client which works well on PC's.
It has been embedded into their webpage at http://www.coastguardcottagecromer.co.uk/page18.html
It is within an iframe which allows fullscreen.
When run on a pc its fine and the full screen button operates as it should, but it does not on an iPad. (both on Safari and Chrome on the ipad.
How can this be fixed so it operates normally on iPad as well as pc?
RS360vts
Likes: 3 posts
Liked in: 224 posts
Re: Full Screen Button not working on iPad
by Destiny » Sun Jun 01, 2014 9:31 am
Hi..
This might work if you set your iframe to something like this...
<iframe src="http://www.Destiny.com/virtualtour.html" width="100%" height="600" allowfullscreen="true" seamless></iframe>
by mediavets » Sun Jun 01, 2014 12:47 pm
RS360VTS wrote:Hi Guys,
RS360vts
I thought that the fullscreen button in a control bar was not displayed when viewing with many mobile devices because fullscreen functionality of these platfforms is unreliable.
RS360VTS
Liked in: 3 posts
by RS360VTS » Mon Jun 02, 2014 8:22 am
Hi John,
I am using a toggle button of my own design for opening full screen.
Will give Destiny's suggestion a try and report back..
RS360VT
by mediavets » Mon Jun 02, 2014 8:28 am
RS360VTS wrote:Hi John,
RS360VT
I'm not sure that the HTML5 fullscreen API is supported by iOS.
