video problem in last update
liucash
by liucash » Fri May 30, 2014 10:18 am
the last version of Panotour generates an error in the video spot when viewed from iphone / ipad (desktop is ok). attached screen error.
Videos created with livepano, no errors either on a desktop on iphone / ipad.
a link where you see the error:
http://www.webandsystem.it/DEMO/archivi ... ur/Salone/
in the previous version of Panotour there was this error.
Liked in: 226 posts
Re: video problem in last update
by Destiny » Fri May 30, 2014 10:28 am
No error my end..
Ouch.. I would really avoid adding a lens flare indoors..
What did you use to capture this pano. Seems to be over optimised...
Love the ceiling.. =D
liucash
by liucash » Fri May 30, 2014 11:16 am
No error? the pc works fine ... the error is only on iphone / ipad. vt all have this error (if created with Panotour 2.1.1)
I love the lens flare =D I use them also as a light for the lamps :p
This pano was taken with Sony Alpha 550, but has been optimized to be viewed in a small iframe (roughly 740x520). I do not care the fullscreen display.
I also love this ceiling ... apartment in Brindisi (Italy)
by mediavets » Fri May 30, 2014 11:31 am
liucash wrote:No error? the pc works fine ... the error is only on iphone / ipad. vt all have this error (if created with Panotour 2.1.1)
May be related to chosen video CODEC.
Liked in: 226 posts
by Destiny » Fri May 30, 2014 11:33 am
Well it works find on my Samsung Note too.. But I need to put on sun glass so the lens flare does not kill my eyes... :p Yucky thing.. :lol: Lamps.. ha.. More like a nuclear power plant... :lol:
No need to optimise in this manner with PTP.. ... PTP slices up the images in sub folders so the pano can be viewed on a device with no issues at good quality... To optimise in this way is defeating the object of the power of PTP..
Destiny....
liucash
by liucash » Fri May 30, 2014 11:46 am
Not a problem CODEC ...
worked well in the previous version of Panotur, I just regenerated the project with Panotour 2.1.1
The videos are in mp4
You try to create a VT with Panotour 2.1.1 and you will see that the videos do not work on iphone / ipad
I thought about removing the lens flare =D
by mediavets » Fri May 30, 2014 1:58 pm
liucash wrote:Not a problem CODEC ...
I don't own or have access to an iPhone or iPad.
What browsers have you tried on these platforms?
Might the video file be too large for these platforms at 5.5+Mb?
It appears to have larger than necessary video dimensions and higher than necessary bit rates for video and audio.
liucash
by liucash » Fri May 30, 2014 4:32 pm
I repeat:
is not a problem of video, worked before. has stopped working from the updating of Panotour
Likes: 13 posts
Liked in: 112 posts
by bdd » Tue Jun 03, 2014 2:06 pm
liucash wrote:I repeat:
The video is set on a spot.
Such videos are not modified by PTP. PTP just copy it in the "spots" directory in the tour directory.
The video is not readable by the iPad : http://www.webandsystem.it/DEMO/archivi ... /video.mp4
Did you modified this video since your previous builds ?
PTP only modifies the videos imported as LivePano.
Users browsing this forum: No registered users and 12 guests
